Jack doesn't fit
Also depending on how low your car is you can place a 2x4 piece of wood in front of the tires and slowly drive up onto them , that will give you a little room under your car .
On my friends car we would get the stock jack and crank it up high enough on one side so that we could fit the hydraulic jack under. Im not to hip on lifting the fenders. If your cars so low that you cant get the stock jack under one of the side jacking points then its way too low and you should raise it a bit.
doo like i do... lift it on the cross member on the front.. put a tower on the side.. .. or just carry that little 2x4 and just parkl the car on top of it.. wich its going ot be a bitch if u dont know how to put ur tires on it....and if u got it that low,.,.. maybe ur fingerswont fit between the tires and fender.... but u can pull it up anyways too. whatever works, works...
hydraulic?! don't be silly! scissor jack it!
honda thought ahead and supplied the car with a jack that can get down to like two inches.
[Modified by wreckedhatch, 4:19 AM 6/20/2002]
well its gets to about 3 3/4 inches. My jack stands sit at 3.5 so its pretty close. Wood trick works so i'll just do that. Stock honda jack is a real pain in the *** to use when the forks are all bent up from trying to crank to so hard.
yeah 2x4 is the way to go cause its free, but i know they do make some sort of low jack that sits hella low....seen it on here before
[Modified by blackEF, 11:56 AM 6/20/2002]
buy some thirty dollar plastic ramps.
they work wonders if you're doing your own oil changed and dont have use of a lift
unless ur car its soo ******* low that even scratches in order to get in there
i tried to take it up on midas and other shopw for **** and my car scaratches and touches before going up.... and i only have a ****** 2.5"drop...
lapchern
Honda Civic (2001 - 2005)
15
May 11, 2010 03:46 PM
216.226.142.95:27016
Apr 7, 2003 04:48 AM
). i jus rolled up on some 2x4's then slid the jack under
