HELP - Battery keeps dying
Old Jun 19, 2002 | 02:14 PM
sidewayz's Avatar
Default HELP - Battery keeps dying
The battery on my 93 EX keeps dying, and I can't seem to fnd out why. I disconnected the positive terminal and ploaced a Digital Multimeter bewteen the battery +ve terminal and the +ve cable to the car, and it read 4 AMPS. I have not been able to find out what drawing 4.3 amps while the battery is disconnected. I pulled all the fuses, one by one, with no change in the 4.3 amp draw. THe only change I had was when I disconnected the stereo harness, which gave me a slight reduction from 4.3 to 4.1 amps. Anyone have any idea?
Old Jun 19, 2002 | 02:17 PM
Eyewitness's Avatar
Default Re: HELP - Battery keeps dying (sidewayz)
i think your alternator might be bad.....
Old Jun 19, 2002 | 02:22 PM
B_CRUZ!'s Avatar
is your alternator bracket powder coated by any chance?
Old Jun 19, 2002 | 02:24 PM
Kris's Avatar
Default Re: HELP - Battery keeps dying (B_Cruz)
alternator?!?!?
Old Jun 19, 2002 | 03:08 PM
B_CRUZ!'s Avatar
Default Re: HELP - Battery keeps dying (WishIHadANiceCarToo)
same thing was happening to Fowler y0! thats why I asked... check out his website for the complete story...
http://fowleryo.20m.com/
Old Jun 19, 2002 | 05:39 PM
sidewayz's Avatar
Well, I put a new battery in on Monday night, made sure that the car started, but didn't drive it. By Tuesday AM it was dead. I bought a new battery on Monday, because my GF drove the car to the store about 5 mins away, came back, and when I went back out a few hours later, the battery was dead. It cwould not even hold the charge, so I thought it was time for a new battery. I was thinking that there may be something draining the battery .
then again, I did replace the alternator belts last week, and I know that it's not absolutely taut, so that may also be a reason why the old battery died, but I don't see how the new one would die after sitting in the car overnight!
Old Jun 19, 2002 | 06:46 PM
CR-V's Avatar
replace alternator.. i had a friend who replaced his battery as often as he changed oil cuz it kept dying... BAD ALTERNATOR leads to it.... take it to a mechanic place and ask them to run some tests/inspections on it
Old Nov 22, 2002 | 03:26 PM
sidewayz's Avatar
Default Re: HELP - Battery keeps dying (BaTTLeWaGoN)
Thought I responded to this post. Anyways, after much searching, I found the problem was a bad cooling fan relay tht was draingin like 3 amps with the ignition off. Replaced it and battery problem solved.
Old Nov 22, 2002 | 04:39 PM
DSeriesBeeKilla's Avatar
Default Re: HELP - Battery keeps dying (Eyewitness)
mydogFahey
Honda CR-V & Element
10
Mar 29, 2015 09:59 AM
gsrpedro
14
Feb 5, 2008 01:14 PM
idewson
Aug 31, 2006 11:45 AM
dog the bounty hunter
Feb 5, 2006 11:50 AM
