Suspension & Brakes Theory, alignment, spring rates....
Question On Suspension Sagging
Old Oct 7, 2007 | 07:09 PM
grilledcheese33's Avatar
Default Question On Suspension Sagging
So heres the deal. I'm running on tokico blues struts and springs right now with 50K on them. I'm looking into lowering it a little more. The setup now is only a 1.3 drop and my plan is to put s techs on the tokicos for a little more drop. The s techs are on the way but I just went out and checked my current ride height out and heres what I discovered: I have a little better than a 2 finger gap all the way around except on the drivers rear which has a 1 finger gap. Now my question is, could this be the strut? If I remember right from my auto tech class in HS (a long time a go, LOL), the spring controls the height, and if its lower than it should be, the spring is sagging. If this is correct I will be fine swapping springs but if its the strut I will just have to buy new struts for the s-techs. The ride isn't bouncy whatsoever and If I do the bounce test, it rebounds back without much at all.
Thanks in advance!
Old Oct 8, 2007 | 03:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would replace the shocks anyway, because Tokico HP's can't handle more than a very mild drop. The S Techs will probably kill them, or finish them off anyway.
Suspension "sagging" is more than likely stock rubber bushings tearing, not actually a spring problem.
Old Oct 8, 2007 | 05:36 AM
Default Re: (PatrickGSR94)
Yea i'm pretty much leaning toward replacing them now. Do you mean like the bushings in the LCA's? Thanks for the help.
S_F
Nov 13, 2018 01:59 PM
likeahstone
Honda Civic (2001 - 2005)
Aug 1, 2008 01:39 PM
stuie08
Dec 2, 2006 11:13 PM
DiPPeD iN miLk Ej CoUpE
Jun 29, 2003 11:42 AM
fiebru1119
Apr 25, 2002 11:26 AM
