v-tech controller in 97 prelude
Old Oct 7, 2007 | 07:00 PM
ekchavez's Avatar
Default v-tech controller in 97 prelude
my rev limiter is kicking in at 6500 rmp after i installed a vafc2 controller how can i change that to 9000 or anything above 8000 rpm help
Old Oct 7, 2007 | 07:42 PM
posHonda's Avatar
Whyd you install a VAFC in there anyways? I honestly dont think anyone should EVER get a VAFC. Build the motor and have the tuner set everything straight. If your motor is stock or not far from it (via i/h/e) than your probably slowing your car down.
Old Oct 8, 2007 | 08:35 AM
gibsanez's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">Whyd you install a VAFC in there anyways? I honestly dont think anyone should EVER get a VAFC. Build the motor and have the tuner set everything straight. If your motor is stock or not far from it (via i/h/e) than your probably slowing your car down.</TD></TR></TABLE>
Old Oct 8, 2007 | 07:39 PM
Padawan's Avatar
Darth ModerVader
Default Re: v-tech controller in 97 prelude (ekchavez)
You cannot alter the rev limiter using a V-AFC. If you installed the unit and your rev limiter has been affected, there's a problem with your wiring.
b16nonoy
Feb 18, 2007 04:46 PM
sublimenerd
Oct 23, 2006 12:37 PM
smkngsr
May 16, 2004 09:08 AM
h0ndap1mp1n
Feb 20, 2004 02:02 PM
type rizzy
Jul 15, 2001 11:05 AM
