Degreesing tranny housing?
Old Oct 7, 2007 | 03:40 PM
DrivinVtec's Avatar
Default Degreesing tranny housing?
is it okay to spray the shaft an housing with degreeser? I was going to take the throw out bearing out an spray to clean it up the relube the shafts. is that okay?
also what sjould i lube the shafts with?
Old Oct 7, 2007 | 05:01 PM
DrivinVtec's Avatar
Old Oct 7, 2007 | 05:48 PM
DrivinVtec's Avatar
up
Old Oct 7, 2007 | 06:33 PM
Fei8Lo's Avatar
Default Re: (DrivinVtec)
Just dont destroy the seal, get a new bearing, its cheap insurance. you dont want to have to deal with later on if it goes bad.
Old Oct 7, 2007 | 06:36 PM
bburtonsk8r2's Avatar
Default Re: (Fei8Lo)
tape off anything you dont want water to get into, i just did this not to long ago, def clean off the shaft.. and grease her up pretty good, i forget the name of the stuff i used, but any all purpose automotive grease should work fine.
Old Oct 7, 2007 | 08:14 PM
DrivinVtec's Avatar
what seal? you mean bearing?
haukurn
Transmission & Drivetrain
May 22, 2011 07:50 AM
fongyz22
Honda Civic (2001 - 2005)
11
Nov 13, 2007 09:14 PM
blackfrohatch
14
Jan 5, 2003 05:40 PM
