OEM fog lights wiring NEED HELP WILL PAY$$!! LONG BEACH CA!
i have oem fog lights for my 05 em2 civic and i would like them to be wired to my parking lights instead of my headlights, so that they come on when my parking light are on and then stay on when my headlights are on. if you know how to do this and live around LA, please let me know and i'll pay you to do it.
thanks.
Modified by euromk1s at 1:58 PM 10/24/2007
thanks.
If you have them wired to your headlights, its more than likely to blow a fuse. Do you have the wiring harness that came with the foglights? Its not as hard as many people think. I had some guys wire the foglights for my EJ7, they made it look like cake. Im also in long beach, so i might be able to help you out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AntiochOG »</TD></TR><TR><TD CLASS="quote">If you use a relay you shouldn't have to worry about blowing a fuse.</TD></TR></TABLE>
He didnt metion anything about a relay. He just said They were hooked up to his headlights. Im thinkin ghetto fabolous style.
they are OEM fog lights that came with OEM wiring harness. I just want them wired to my parkinglights and not my headlights.
It can be done....OEM does use relay....
http://www.civicforums.com/for....html
http://www.handa-accessories.com/civic/05fogs.pdf
I attached multiple instructions for the fog install...same thing different point of view
You must disconnect the fuse panel to tap into parking light to trigger your foglight....
Look at the last page of the PDF file and the switch is the trigger for the foglight...RED/YEL HOT WITH Headlight Switch...you must change this portion to tap into parking light
ruff_ridaz86
Oct 24, 2006 10:28 AM
