cable to hydro for my crx
im planning on buying the kit.... my friends tell me that i could just get the kit and just take my original cable and hook it right up to the hasport kit.. And that they said i dont need the hydro fluied lines with the mounts.. meaning like do i need the fluid system to or no?
i just put a b16 with a hydro tranny in my crx.... i used the same kit for my install and the answer to you questions is no!!! you dont need it bc the install kit takes the place of the clutch slave cylinder. so you can go ahead and remove all the hydro hardware from the transmission.
that pretty much is everything in a nut shell....
if im wrong please correct me!!!
thanks fellas...
thanks fellas...
SomeDude56
Dec 26, 2005 11:13 AM
