KS---FS---92 integra w/B18C1
ASKIN 2000
rebuilt b18C1
compression 215 all across on it no grinds at all
92 gs obd1 body
94 gsr b18c1 with matching p72 head
ys1 cable tranny
stage 1 exedy street clutch
ngk 8mm wires(blue)
ls dizzy cut to fit
kyb struts in the front . stock in the back
some ebay header
stock exhaust
ngk iridium plugs...
felpro 3 layer head gasket ( oem style )
resurfaced the flywheel b4 assembling
copper sprayed all gaskets except for throttle body for good seals
NO BLINKERS
all wiring is done some what right
obd1 p72 with no codes showing so is running right.
theres a hole in the exhaust so it sounds like **** ....
all sensors that were required for p72 are on the block it runs good but could run better with a gsr dizzy ....
vtec doesnt engage needs somethin minor
it has LS meshes on it
will get new pics today
rebuilt b18C1
92 gs obd1 body
ys1 cable tranny
ngk 8mm wires(blue)
ls dizzy cut to fit
some ebay header
stock exhaust
NO BLINKERS
s10cky
Nov 20, 2007 11:06 AM
