Suspension & Brakes Theory, alignment, spring rates....
rear toe adjust bolt (where can I get it?)
Old Oct 7, 2007 | 09:29 AM
CooBlueDAB's Avatar
Default rear toe adjust bolt (where can I get it?)
Does anyone know the actual part number for the nut, that goes on the inside of the sheet metal for the body connection of a compensator arm? This is a 99 civic SI. And the nut itself is the one that usually gets stuck and falls in the metal. It is this one in the picture below. I need it bad... Mine are totaled. Rust owned me. If no part, is there an alternative? Thank you very much, this is a very urgent need of mine.
Old Oct 7, 2007 | 06:18 PM
Targa250R's Avatar
be professional
Default Re: rear toe adjust bolt (CooBlueDAB)
There is no part number, because you can't buy those from Honda. They are pretty much non-replaceable, since you have to cut holes in the chassis to access them.
Your only option, if you can't find a similar piece at a hardware store, is to cut into another Civic at a self-serve junkyard to pull a few.
Old Oct 7, 2007 | 06:42 PM
slammed_93_hatch's Avatar
Default Re: rear toe adjust bolt (Targa250R)
i'd just get a stainless steel metric nut from a hardware store and weld it onto a plate the same as the stock setup
DVDr
Nov 11, 2018 01:40 PM
integrainside
Suspension & Brakes
Nov 6, 2013 02:02 PM
Lifetrip718
Suspension & Brakes
Aug 10, 2013 05:47 AM
Setsuna F Seiei
Welding / Fabrication
May 22, 2006 05:12 AM
CivicEK.PDX
Sep 12, 2002 06:42 PM
