possible bad fuel pump?
Old Oct 7, 2007 | 09:25 AM
dj-t's Avatar
Default possible bad fuel pump?
I just put in a b18a in my 90 hatch si and I can't get the damn thing started it turn and everything sounds like its about to catch on but no luck. I checked my grounds, all the fuses, switched out the main relay still the same thing. I pulled off the fuel line going to the fuel filter and turned it on no fuel. So I checked the fuses again all good. I pulled the back seat off and checked the wire going to the gas tank. I metered the wires and this is what I got, the yellow/white wire I got 5.8 volts when turned to ignition, black/white tested ground, black with two gray dots tested ground, yellow/black with two gray dots tested ground when ignition on and nothing when ignition off. But when I plugged the harness back the section that goes into the tank all the wires still checks out the same except for the yellow/white the voltage drop from 5.8v to .80v. What do you guys think do I have a bad fuel pump or something went wrong with the electrical. Thanks.
Old Oct 7, 2007 | 04:25 PM
1 Fly SI's Avatar
Default Re: possible bad fuel pump? (dj-t)
Just run power to the fuel pump for a second to see if it is working or not. If it does than your problem is electrical. If not than the pump if dead.
Old Oct 7, 2007 | 04:35 PM
.Grimace's Avatar
footwork mastery
Default Re: possible bad fuel pump? (1 Fly SI)
when you turn the key to aux. power do you hear it prime?
Old Oct 7, 2007 | 08:36 PM
dj-t's Avatar
So just run a 12volt wire to the yellow/white and listen for the pump. Damn it!! Why didn't I think of that this morning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">when you turn the key to aux. power do you hear it prime?</TD></TR></TABLE>
Nope I did not hear it prime at all. At first I thought it was the pump cause I didn't here it prime but I decided to check everything possible first cause a buddy of mine says that I have to take down the gas tank to change the pump. Thats when I found that the yellow/white wire only put out 5.8volts. Don't most of the components in the car take 12v DC?
Boosted_90Teg
Jan 25, 2013 04:04 PM
Thor777
Nov 27, 2011 07:07 PM
Destructive-
Audio / Security / Video
31
Feb 27, 2011 12:59 PM
4potnick
May 24, 2003 11:17 AM
