OIL SPILL RESULTS
Old Oct 7, 2007 | 09:21 AM
robble36's Avatar
Default OIL SPILL RESULTS
my dumbass friend kicked over 3 quarts of old oil that just came out of his car in my garage... it was a giant mess @ 10pm at night it was everywhere, in the garage, driveway, street, and drain.... we hit it with just soap and pressure washer and then i woke up this morning to assess the damage.. it was a nightmare there was blotches every where....i am now in the process of cleaning it .. im going to post pictures and you guys can decide if you would use this chemical or not
Old Oct 7, 2007 | 05:55 PM
Muckman's Avatar
Moderator in Chief
Default Re: OIL SPILL RESULTS (robble36)
ok thanks for the heads up
Old Oct 7, 2007 | 11:17 PM
blinx9900's Avatar
Default Re: OIL SPILL RESULTS (Muckman)
i do believe there is a GDD forum...
Old Oct 8, 2007 | 06:59 AM
Dogginator's Avatar
Daisy... Daisy...
Next time, dump kitty litter or oil dry on it.
Old Oct 8, 2007 | 07:48 AM
thesmogman's Avatar
Laundry detergent- the dry stuff. Add water work it in and let it sit for a bit and rinse. Does a great job.
I used it on a big spot in the garage, then had to do the rest.
Old Oct 8, 2007 | 07:54 PM
robble36's Avatar
Default Re: OIL SPILL RESULTS (thesmogman)
that was the damage i couldn't get a better picture of inside the garage because of lighting but you get the idea..
i used Drive Up got it at autozone.. i am pretty satisfied with it and it works best with scrubbing and a pressure washer of course but it lifted the oil right up... ill post pictures of my driveway as it is now tommrrow since it is dark outside already
DFW
Welding / Fabrication
13
May 11, 2008 09:43 PM
jetlude
Mar 7, 2008 03:14 PM
alexsracing
Jan 23, 2008 06:07 PM
is3oo
Jun 6, 2004 06:49 AM
Rhetoric
Aug 6, 2003 12:59 AM
