95 Civic EX Auto to 5 speed help
Hey im having trouble finding a tranny to change my civic to a 5 speed and was wondering if anyone knew where a good place to find one was.
Also when i do the conversion will i find many problems trying to do this? [ex. will there be a lot of cutting involved.]
Thanks
Thanks
Honestly man, unless you are absolutly in love with this car or just like huge projects, it save A LOT of hassle to just buy a 5-speed Civic. Honda tranys seem hard to track down but I would bug HAPrecycling for one if I where you ($$$$.$$).
irst, search in the FAQ there are write ups on how to do this. second, get a trans from a junk yard and have it gone over to make sure the gears dont grind, and the main bearing isnt fucked. third, its not that hard to do this swap. just make sure you get the manual flywheel bolts, a new clutch kit, and the correct throttle cable for the pedals you get. any 92-00 civic and 94-00 tegra will work. you can use your axles and int. shaft. you will need a manual trans speed sensor as the auto one wont fit. its all in the write up.. have you even looked in the FAQ section since you became a member ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">i'd try searching the marketplace. there's tons of parts. also, you could try a local junkyard. any tranny from any civic 92-00 should work iirc.
do you have the other parts needed to do the swap?</TD></TR></TABLE>
^^^ yeah, I see people selling D16z6 and y8 transmissions for like $150 or so all the time.
Search for threads created by LUSERKID... he did a write up on auto to manual
