porn avatar
Old Oct 6, 2007 | 10:02 PM
viciousef9's Avatar
Default **** avatar
my friend has a new avatar and once to know if you can use any **** avaTARS
Old Oct 6, 2007 | 10:13 PM
CRX MASE's Avatar
Default Re: **** avatar (viciousef9)
This isnt the right area to post about this.
Old Oct 6, 2007 | 10:14 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viciousef9 &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a new avatar and once to know if you can use any **** avaTARS </TD></TR></TABLE>
why'd you create two thread's on this? IBTL
if you want to get banned or lose percentage points, then yes, you can use a **** avatar.
read honda-tech rules:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech's Terms of Service &raquo;</TD></TR><TR><TD CLASS="quote">- Avatar Guidelines
* Common sense should rule however since some of you seem to lack it we have written the rules for everyone to see. You may use any avatar that does not fall under any of the following categories:
o Sexually Explicit/Pornography (Clothed or not)
o Nudity (regardless of whether private parts are shown or not)
o Figures in a sexual or "prone" position (clothed or not)
o Images that show private parts through clothing (eg: wet t-shirt pics)
o Images that are racially, politically or religously offensive
o Images that contain vulgar or profane language
o No avatars of a drug/narcotic nature
* Basically if you could expect to see it in public then it is probably ok. Public places mean malls, stores, parks etc. Nude beaches ARE NOT considered public places.
* Groups and associations retain the right to hold a copyright to an associative, original avatar. Avatars taken from other member's without the express permission from the original holder are subject to removal.
* The Mods/Admins also reserve the right to rule on any avatar in a case-by-case manner. The above is a MINIMUM acceptable set of rules to follow. Keep in mind that this site is viewed by many people at work. Images that fall under any of the above categories are not appropriate for a work environment.
* Penalties For Violations:
o Your avatar will be removed and you will be warned. You will not be asked to change/remove it. We will do so for you.
o If you use a new avatar that meets the above criteria then no further action will be taken.
o If your new avatar does not meet the above criteria then your avatar will again be removed and you will lose your avatar privileges indefinitely.
o The Mods/Admins also reserve the right to ban members who blatantly disregard the criteria after their initial warning.
* If you have any questions regarding the appropriateness of an avatar please message either Drew M.</TD></TR></TABLE>
Old Oct 6, 2007 | 11:51 PM
Hamstr323's Avatar
Default Re: **** avatar (gursh d)
if you have to ask it's probably not a good idea
and why would you ask here?? you should learn to read the RULES!
Old Oct 6, 2007 | 11:58 PM
Pee Wee's Avatar
Default Re: **** avatar (Hamstr323)
this forum has gone to shat thanks!
Old Oct 7, 2007 | 01:04 AM
~sp33~'s Avatar
EFB055
Default Re: **** avatar (Pee Wee)
Reported. Dude... seriously.
viciousef9
Oct 6, 2007 10:14 PM
Francesco
Honda S2000
112
Jan 5, 2006 04:22 AM
@irborne
Welding / Fabrication
17
Nov 6, 2005 04:32 PM
superteg_21
Jul 13, 2003 12:47 PM
GreenBean
Apr 13, 2003 01:43 PM
