which is the better type of weld or is it just the same?, slip fit weld vs beveled edge butt weld
i was just wondering and would appreciate your answer/reasoning as to why, if, one is preferred over the other.
also, which type of welding works best with which one, or is it just the same? maybe its a convenience to use the slip fit method and then weld, compared to the other because it holds/stays in place?
discuss...
discuss...
A welded slip fit will generally be stronger....but a butt joint is a lot easier and in most cases strong enough if properly welded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 »</TD></TR><TR><TD CLASS="quote">A welded slip fit will generally be stronger....but a butt joint is a lot easier and in most cases strong enough if properly welded.</TD></TR></TABLE>thank you for the reply.
