OBD0 to OBD1 few questions
Old Oct 6, 2007 | 05:33 PM
markviiisvt4's Avatar
Default OBD0 to OBD1 few questions
I just got done building a jumper harness for my buddys hatch and I had a few questions. I'm using a P06 ECM.
First question I've read that a few of the jumper harness you can buy have two wires you can tie together to get the codes from your ECM any one know what they are?
Number 2: When I was all done I only had one wire left to go to the O2 sensor, wich is the heater control. Am I correct in thinking that two of the wires on the o2 sensor are grounds, wich can go to a ground. 1 Wire goes to my heater control wire, and the last wire ties into the old signal wire thats already under the hood. Is this right?
Number 3: The ecm we got is for an auto, wich resistor is it that I need to remove to keep the MIL at bay?
Seems like i had one more but I can't rember right now.
Thanks in advance guys.
Old Oct 7, 2007 | 05:10 AM
Default Re: OBD0 to OBD1 few questions (markviiisvt4)
figured out my first question. The wires from D04 and D07 are the wires that get jumped together to check the engine codes. Just in case any one else was woundering.
claymonthug
Feb 14, 2010 06:17 PM
sirmugenpower
Mar 13, 2009 08:27 PM
hatchnideas
Jul 14, 2007 12:24 PM
KevronsEG
Mar 31, 2003 10:11 AM
