camshaft caps
got a problem, one of my camshafts caps , not the rails but it is stripped it on the driver side intake side if your looking at the engine front you.if you are facing engine front of you right corner. you should know what i mean. i was just wondering where can i get other one or someone selling one. I've searched and i couldn't find answer no where help me out
when you look at where number 16 is on the image if you follow it down to that cap that the one is stripped it should say on the cap I1-1 on there
The cam caps are not sold seperately because they are matched to the head. Since the bolt in question holds part 6, you could try to drill and tap for a threaded insert or try helicoil.
