What is it worth?
I have a used Comptech ECU out of a 98 Type R. What is it worth?
The Comptech ECU works on a modified version of the stock ECU. It lowers the vtec point to around 5400 rpm and moves the rev-limiter up 200 rpm above stock. Because it is a modified stock ECU the air conditioning controls remain intact. The timing is advanced slightly.
I'd think it should be worth something in the range of $350-400.
Especially since it would plug right into a 97-98 ITR w/o the need for a harness adapter.
Would consider taking it off your hands if I didn't already have a spare Mugen ECU sitting around.
hYpE-R-29
Nov 15, 2002 08:33 AM
