CEL Misfire
Old Oct 6, 2007 | 10:43 AM
ttypez's Avatar
Default CEL Misfire
Hey guys, I've got p0301 cylinder 1 misfire and a pending p1399 random misfire code on a 2001 accord with a 4cyl. In the last 48 hours the plugs, wires, cap and rotor have all been changed. Any ideas? Clean out the egr? fuel injector maybe?
Old Oct 6, 2007 | 10:52 AM
boostedh22lude1's Avatar
Default Re: CEL Misfire (ttypez)
possible injector, does it have individual coils? if so swap the coil with another and see if the missfire moves cyl. but id would say inj.
Old Oct 6, 2007 | 04:31 PM
jravensc's Avatar
Default Re: CEL Misfire (boostedh22lude1)
I worked on a Nissan with a similar code and had to replace the knock sensor.
Old Oct 6, 2007 | 06:04 PM
Duane_in_Japan's Avatar
Valve adjustment.
Old Oct 6, 2007 | 08:22 PM
YeuEmMaiMai's Avatar
first, do you get it at low or high rpms?
since this is not a DIS engine, I would suspect ignition module.
Cars with individual coil packs on top of the spark plug do not have spark plug wires
scarney
Aug 16, 2008 06:10 PM
zirac50
Mar 4, 2007 10:41 AM
crum
Oct 10, 2005 06:42 AM
revvin9k
Nov 8, 2004 04:25 AM
EK_vzla
Aug 30, 2004 01:39 PM
