b16 02 sensors
Old Oct 6, 2007 | 08:15 AM
redsi89's Avatar
Default b16 02 sensors
so as usual i've heard a number of different things about o2 sensors my swap. where they should be, how many, how i should hook them up. i have an 89 si with an obd0 b16. i have one o2 sensor and i have a bung already in the cat i bought should i just tap the secondary o2 into the primary and run it like that or place both of them in the header on their own? i would appreciate the help i'm o close to having this thing running
Old Oct 7, 2007 | 08:17 AM
redsi89's Avatar
Default Re: b16 02 sensors (redsi89)
anyone wanna drop some knowledge on me here. i see ya lookin
Old Oct 7, 2007 | 08:22 AM
Loserkidwac's Avatar
Well OBD0 uses non-heated O2 sensors so you should kep them as close to the head as possible, if you have a stock B16 exhaust manifold there should ne 2 O2 ports on it...the best method would be to wire them seperately and have them in the stock location, the cat bung is going to be to far away unless you were to convert to OBD1 and us a 4-wire O2 sensor...splicing the them together will work but won't be the best results...
Old Oct 7, 2007 | 08:24 AM
91ed9's Avatar
why dont you search for o2 sensor in the search button there is a lot of infor there no one wants to read
but b16 obd0 needs 2 o2 senors and the need to be on the header bc they arent heated 02 sensors so they need to be close to the engine so it doesnt run like **** until it warms up primary i believe is cylinders #1 and #4 and secondary is #2 and #3
solocrx
Feb 14, 2009 03:18 AM
allnaturalb16
Nov 15, 2006 09:45 AM
90hbvtec
Dec 5, 2003 07:42 AM
