Buddy Club Spec 3 or Spec 4 Cams?
Old Oct 6, 2007 | 08:09 AM
EK499's Avatar
Default Buddy Club Spec 3 or Spec 4 Cams?
Hi guys, I would appreciate your advice on what camshafts to purchase for my EK4. I have no major modifications on my B16A2 engine, just intake, exhaust, pulleys, cam gears, fuel pressure regulator and an ITR p73 ECU. I would like a set of cams that I will be able to start using them inmediately without having to make major modifications at least for a while. Do you know if the Spec 4s will necessarily require a better ECU, higher compression, bigger injectors, etc or those will be just desired mods?
Thanks,
Javier
Old Oct 7, 2007 | 11:37 AM
doood's Avatar
been there done that
Default Re: Buddy Club Spec 3 or Spec 4 Cams? (EK499)
sounds like you want the spec 3's. the IV's are much bigger cams and like more compression and higher revs. you'll need tuning with any set of cams regardless. either will require stiffer valvesprings.
EG617
Jan 21, 2005 08:59 PM
Anone
Aug 2, 2004 01:21 AM
vtec94civic
Dec 15, 2003 07:37 PM
Engo
Apr 7, 2003 04:40 PM
