why me dpfi to mpfi conversion
Old Oct 5, 2007 | 08:48 PM
turbozcteg's Avatar
Default car starts but has no power
oik heres the thing
i jsut did my 2nd conversion and it went great fired right up after refilling the lines with fuel lol
but now it sounds like im runnign on 3 cylinders
and when i rev it up it bogs and then the rpms go up
my question is do i have a plug backwards or something
the timing is all good already checked that
also does any one have the vaccume setup for the multipoint setup
my problem could also be from backwards vaccume hoses or something
please help me out
thanks
~jake
Modified by turbozcteg at 8:05 PM 10/6/2007
Modified by turbozcteg at 9:25 PM 10/6/2007
Old Oct 6, 2007 | 11:05 AM
turbozcteg's Avatar
Default Re: car starts but has no power (turbozcteg)
bump
Old Oct 6, 2007 | 04:16 PM
SFlCrx's Avatar
hows the idle is it low, jumply, make sure the plug wires are in the right place first
Old Oct 6, 2007 | 05:20 PM
turbozcteg's Avatar
Default Re: (SFlCrx)
the idel is a little jumpy
abd when i rev it it sounds like a fricking lawn mower
and is putting out smoke like its running rich so im gonna start with checking the injector wiring
but if any one has the vaccume diagrams let me know ok
Old Oct 6, 2007 | 09:00 PM
SFlCrx's Avatar
sounds like vaccum what color is the smoke
Old Oct 6, 2007 | 09:06 PM
SQ is the SQUAD's Avatar
did you rember to swap around the tps wires? if you did already do it try putting them back the correct way, i hear some cars dont have to be swapped around
Old Oct 7, 2007 | 03:21 PM
turbozcteg's Avatar
Default Re: (SQ is the SQUAD)
i did swap them around for the swap
but i have not switched them back
i am firing on all 4 injectors
but i took off my cap and its toast so im going to get a new cap and see if that fixes the problem
Old Oct 9, 2007 | 01:24 PM
turbozcteg's Avatar
Default Re: (turbozcteg)
replaced cap and rotor and found out the main relay was burned threw meaning had a fricking hole burned threw it lol
so time to replace the main realy then see what happens
ill keep you updated
Old Oct 9, 2007 | 02:33 PM
welfarepc's Avatar
theres only 2 vaccume lines... it cant be hard to trouble shoot that
Old Oct 10, 2007 | 11:46 AM
turbozcteg's Avatar
Default Re: (welfarepc)
hmmmmm no i have 4 lines and 5 open hose nipples
so then i have to t 1 of them off to make 2 but where do tey go huh
and also i got it started but the idel is real high
is this caused by the vaccume lines ????
or is there something else ??
818blue818
38
Mar 20, 2012 03:51 PM
aschrock
Oct 27, 2011 02:55 PM
RA5_Prestige
Aug 9, 2011 09:08 PM
EJAYATE
Feb 5, 2008 09:38 AM
