Question regarding 96-00 coupe?
I was just wondering what rear bars are interchangeable form another honda/acura?I have heard that the dc2 rear bars fit the ek but do they also fit the coupes?Thanks
all 96-00 civics have the same subframe, save for the ctr (reinforced to survive fatty sway bar) and i believe the Si (nuts welded behind the D-bracket, someone correct me please), so what fits a hatch will fit a coupe will fit a sedan.
dc2 bar, assuming ls or gsr, you need the em1 mounting plates, dc2 D-brackets/bushings, em1 endlinks. bigger than those and youre likely to be into itr range which would all but mandate reinforcement of the mounting points via ASR or Comptech pieces.
Your answer has nothing to do with my question so why did you bother?
I am asking a simple question that I dont have the answer to so your opinion on whether it works or not is irrelevant.
chads
May 15, 2004 02:14 PM
heel_touge
Jan 26, 2004 11:22 AM
