Headers.. So many to choose from...
Old Oct 5, 2007 | 04:57 PM
Zappythebum's Avatar
Default Headers.. So many to choose from...
Ok so i just purchased a 2000 ITR Cat-back exhaust straight from the dealer and the guy there told me that if i wanted to get headers that my main choices would be between:
Stock USDM ITR headers
or
DC Headers(because carb legal)
When i asked him about the JDM ITR headers he said that the a pipe would be too low and possibly hit the ground while i was driving.
I was also curious about ceramic and stainless steel headers and he said that ceramic coating is to lower the heat retention of the metal and stainless was just for looks.
So! Coming from that.. does anyone have experience in purchasing headers for a an integra? Doesn't matter what kind. What problems you might have run into or anything like that? And can you install them at home.. or does it have to be done at a shop? Thanks for all your help
Mine is a 2000 LS and just for info, the headers need to have a 2.25 collector to fit my cat. Any kind of feedback will help.
Old Oct 5, 2007 | 06:10 PM
Padawan's Avatar
Darth ModerVader
Default Re: Headers.. So many to choose from... (Zappythebum)
If you're trying to stay C.A.R.B. legal, then your choices are relatively limited. DC Sports and Greddy are decent, and if you can find a Comptech header, that would be a nice choice.
Old Oct 5, 2007 | 06:43 PM
SleeperGSR's Avatar
Default Re: Headers.. So many to choose from... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zappythebum &raquo;</TD></TR><TR><TD CLASS="quote">
You'll probably only need one header. Jokes aside, you might as well upgrade to a high flow cat if while you are doing so much work to your exhaust. The type r cat isn't too expensive and that has 2.5 collectors. the larger diameter is better for a N/A car. That being said look around there are many different companies that make a header for an integra. I got a megan for 200$, fitment was great and they stand behind their product.
Old Oct 6, 2007 | 11:56 AM
Default Re: Headers.. So many to choose from... (SleeperGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">
The type r cat isn't too expensive and that has 2.5 collectors. ... I got a megan for 200$, fitment was great and they stand behind their product.</TD></TR></TABLE>
The type r cat from the factory is $938 i checked. and the whole system is 2.25"...
From what i hear megan isn't too great
Does anyone else have any experience? And yes i probably will be leaning towards the C.A.R.B. legal side of things
Old Oct 6, 2007 | 12:04 PM
pinoy2o9's Avatar
get either DC or greddy if your leaning toward C.A.R.B
there both good products. both around the same price as well.
Old Oct 6, 2007 | 12:07 PM
VTEC13's Avatar
I have a 95 Gsr and just instaled some DC headers. They fit perfect and sound good. You should be able to do them in a garage. It would help a lot to have someone to help you though. Oh and go with the ceramic.
Old Oct 6, 2007 | 12:10 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">The type r cat isn't too expensive and that has 2.5 collectors. </TD></TR></TABLE>
The USDM cat has a 2.25" collector. The JDM ITR cat has a 2.5" collector.
Old Oct 6, 2007 | 02:56 PM
Da9Gro's Avatar
ZR headers are CARB legal too and they're a lil bit cheaper than Dc's but they're good my buddy had em in his 2000 teggy ls and he loved it
Old Oct 6, 2007 | 04:46 PM
Redbone's Avatar
I have a megan SS header on my gsr swap and it fits good. Only problem is it hangs LOW. I have hit that thing so many times i already need a new one.
Old Oct 6, 2007 | 06:16 PM
Padawan's Avatar
Darth ModerVader
Default Re: Headers.. So many to choose from... (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">The USDM cat has a 2.25" collector. </TD></TR></TABLE>
It's actually 2.0", which is the same as the other USDM Integra models.
Old Oct 7, 2007 | 08:24 PM
Thanks for all the advice guys!
Old Oct 7, 2007 | 10:50 PM
sw388's Avatar
ooh!!! the dealer probibly charged you an arm and a leg!! you could have gone with a used JDM itr exhaust and thats all 2.5 in and that would have fit nicely with a itr header.
as far as the header honda designed the header so each pipe is NOT stacked on top of another(as dc, powercore and most other replica type-r headers) as it journeys under the oilpan to the collector of 2.5 in.(on the jdm model).. as far as dc they crack at the welds im guessing the HAZ (heat affected zone) was indeed affected and later cracked on my header and most everyonelsess..lol but since your are in cali dc and edelbroc (spelling?) could be options.. but o.e. is never a bad route
Old Oct 7, 2007 | 10:55 PM
clean3two3's Avatar
i got a 92 teg and was also thinking of getting headers but whats the difference between 4-2-1 headers and the whole straight pipe headers? and whats better
Old Oct 7, 2007 | 10:58 PM
gsrob's Avatar
As Padawan said above, Comptech makes a pretty nice header. Or they did, some of their ex-employees are in the process of reopening the company. You can still probably find a used one or new overstock for the time being, but they aren't exactly cheap. They are carb exempt though. My boss got a JG edelbrock header and welded the carb exempt plate to it from a Comptech header. It is now "legal". It even passed at the referee in California, pretty surprising.
Old Oct 7, 2007 | 11:00 PM
gsrob's Avatar
Default Re: Headers.. So many to choose from... (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 92 teg and was also thinking of getting headers but whats the difference between 4-2-1 headers and the whole straight pipe headers? and whats better </TD></TR></TABLE>
I believe most, if not all headers for 90-93 Integra headers are going to be 2 piece 4-2-1 designs since the single piece ones are pretty much impossible to put in with the subframe in the way. I could be mistaken, those are just my observations from looking around a little bit. I have had to order one before for a 92 teg but I haven't owned one.
Old Oct 7, 2007 | 11:19 PM
AxelFoley95GSR's Avatar
If its already smogged just buy an ebay header, I havnt had any issues with my ss ebay header. And you can make your own carb plate at petco with a dog tag and have a muffler shop tac weld it on for you patna! trim the edges though.
Old Oct 7, 2007 | 11:39 PM
clean3two3's Avatar
Default Re: Headers.. So many to choose from... (AxelFoley95GSR)
alright cool. but yeah one thing whats better 4-2-1 or a whole piece header just asking cus for my 92 teg they only sell the 4-2-1 so i guess ill just buy one of those.also what is better ceramic or stainless steel? and are those ebay headers any good?
Old Oct 8, 2007 | 02:03 AM
sdr KEL's Avatar
i ride slammed. n also rockin jdm itr headers.. keeping htat stock look n also makin power at the same time..
if anyones interested im sellin these headers
http://www.hondamarketplace.co...15453
Old Oct 8, 2007 | 07:47 AM
rkrone's Avatar
Default Re: Headers.. So many to choose from... (sdr KEL)
DC sports 4-2-1 headers fit a DA with no clearance issues, i had them when i was N/A.... still got them (selling)
Old Oct 8, 2007 | 07:56 AM
dizzzane's Avatar
Default Re: Headers.. So many to choose from... (rkrone)
4-2-1 makes better low end, 4-1 makes better high end, in theory.
jxhxb
Apr 9, 2009 11:27 PM
djteggy99
May 19, 2008 08:09 AM
SiR Inspired ED7
Oct 23, 2004 09:47 AM
