Type S cams for US spec H22A
Old Jun 19, 2002 | 11:06 AM
spoolinGTI's Avatar
Default Type S cams for US spec H22A
I have a friend with a 2001 base model Lude. He has Type S cams, Vtec AFC, I/E, and pulleys. His car has gotten NOTICABLY slower, and Ive read quite a few times about the negatives associated with the Type S cams although I cant seem to find anything on the search.
Please post your experiences, information, comments, etc, because he is almost sure that the cams are not the cause for the performance decrease.
TIA.
Ken
Old Jun 19, 2002 | 11:08 AM
laughinxxx's Avatar
New User
Default Re: Type S cams for US spec H22A (spoolinGTI)
Has he gotten dynotuned yet?
Old Jun 19, 2002 | 11:12 AM
JG Luder's Avatar
Default Re: Type S cams for US spec H22A (laughin2.2)
has he increased the compression? If not, then this is probably his issue.
Old Jun 20, 2002 | 09:48 AM
EGh22aEG's Avatar
Default Re: Type S cams for US spec H22A (Todd 94)
what would he increase the compression to?
Old Jun 20, 2002 | 12:19 PM
EH2DX's Avatar
dyno is your friend
Old Jun 20, 2002 | 01:23 PM
ludespeeder's Avatar
Default Re: Type S cams for US spec H22A (BB1)
I'd say use the type-S pistons as well with the camshafts, that's what I did and milled a little off the head. I'm running a little over 12:1 compression and I have no problems out of the cams, I still need dyno tuning tho.
Old Jun 20, 2002 | 10:12 PM
satan_srv's Avatar
Default Re: Type S cams for US spec H22A (ludespeeder)
Can you cover the differences in the Type-S camshaft vs. a regular H22a camshaft?
Old Jun 21, 2002 | 08:47 AM
spoolinGTI's Avatar
Default Re: Type S cams for US spec H22A (satan_srv)
yes....please give more details. I remember reading quote a few post about the negative aspects of swapping US spec h22a camshafts for the JDM camshafts.
Ken
Old Jun 21, 2002 | 09:26 AM
EGh22aEG's Avatar
yea i have those cams to and my car isnt running as good as it should eigther i need to know how to fix this
Old Jun 22, 2002 | 12:21 AM
aeolus's Avatar
Default Re: Type S cams for US spec H22A (esp169)
Just out of curiosity???Have you guys opened up the valve cover yet to see how the cams broke in???
Old Jun 22, 2002 | 07:34 AM
EGh22aEG's Avatar
Default Re: Type S cams for US spec H22A (aeolus)
i have opened my valve cover before and they looked fine but im not expert on cams
Old Jun 22, 2002 | 01:01 PM
spoolinGTI's Avatar
My friend recently had his valves adjustment done, and afterwards, he asks the mechanic if the head looked fine, or if it looked like something was wrong due to the cams.
The mechanic said that everything looked fine, and that there wasnt any metal debris floating around so it should be fine, although I am skeptical.
Ken
tesh
Jun 26, 2008 09:20 AM
B18cHatch06
Apr 12, 2006 10:17 PM
mgags7
Feb 1, 2005 05:03 PM
blk97lude
May 15, 2003 03:17 PM
aeolus
May 3, 2002 12:43 AM
