Boosted Integra - My new build
Not much of a new build. But here was the lowdown.
old setup
New setup
NEW:
UGR cast manifold
3" downpipe
Borg warner turbo
2 slim fans
full radiator/consensor
FULL A/C (cold as ****)
3" inlet 4 1/2" tip Apex N1 Turbo muffler
3" mandrel bent pipe
New intercooler piping
Here's some old pics of the car
old setup
New setup
NEW:
UGR cast manifold
3" downpipe
Borg warner turbo
2 slim fans
I actually traded mine plus cash for some blades.
I like the blades much better. Cheaper tires too. It's a daily driver!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jo3f1sh »</TD></TR><TR><TD CLASS="quote">Holy ****...2 fans...AND A/C? Well done my friend...
Thank you so much man, it was well worth the work.
</TD></TR></TABLE>Thank you so much man, it was well worth the work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">who tuned it and how much power are you putting down. Impressed with the dual fans and a/c</TD></TR></TABLE>
It is not tuned.
I was going to do hondata s300 but the guy who did my welding said he could do better with an AEM. So i'm going the route in a few weeks.
Along with installing the turbo timer, air/fuel gauge
It is currently running 7lbs. I may bump it up to 9 or 10 for the tunning
It is not tuned.
looks clean man! turbo + A/C = FTW! if u want more room in the engine bay convert the fans to the other side of the AC condensor! I have a 12" and 10" fan set up the same way, looks good too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">looks clean man! turbo + A/C = FTW! if u want more room in the engine bay convert the fans to the other side of the AC condensor! I have a 12" and 10" fan set up the same way, looks good too.
Two pullers fans > two pusher fans
So I've heard!
</TD></TR></TABLE>Two pullers fans > two pusher fans
So I've heard!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny »</TD></TR><TR><TD CLASS="quote">
So I've heard!</TD></TR></TABLE>
according to the laws of thermodynamics i do not see how that statement could be true...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">
according to the laws of thermodynamics i do not see how that statement could be true...</TD></TR></TABLE>
Actually, he's right. The puller fans make flow through the radiator much more laminar, increasing the amount of heat taken off of the radiator fins. A pusher fan chops up the air as it goes through the fan, disrupting airflow and reducing rate of heat transfer to the air.
