Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
UGH THE PROBLEMS KEEP COMING!!!
Old Oct 5, 2007 | 02:38 PM
rowo87's Avatar
Default UGH THE PROBLEMS KEEP COMING!!!
(2001 Honda Civic Coupe EX) I had my head gasket changed and the head shaved, they also changed the thermostat. So now I'm happy to finally get my car back and I'm driving home when I make a U-turn. When I accelerate out of the turn I can almost feel the power steering dislocate and I swerve dangerously into the next lane. I'm gonna kill myself driving this car. I took it back to the shop and they said because it was raining maybe the wheels are spinning... bullshit. I can feel the steering wheel lose power... It won't pull back into straight position when exiting the turn... So I changed the power steering fluid, drained it completely and put all new fluid in it... Still doing the same thing... On top of this the car has lost a ton of HP, I used to feel a jerk when V-tec kicked in, now it's more of a gentle push... I can floor it and it feels like I'm accelerating to merge or something it's pathetic. WHAT DID THESE PEOPLE DO TO MY CAR!?!?!?!
Old Oct 5, 2007 | 03:06 PM
i-VTEC_DOHC's Avatar
very simple. they eff'd you in the A
Old Oct 5, 2007 | 03:09 PM
rowo87's Avatar
Default Re: (i-VTEC_DOHC)
I mean what part of changing a head gasket has anything to do with steering?
Old Oct 5, 2007 | 03:38 PM
oh lol hmm well..absolutely nothing that i can think of. but they eff'd you pretty good... i dont think they used ky either lol jk but idk.. they might have tinkering around like most shops do. i think ur ps pump is goin out
Old Oct 5, 2007 | 03:47 PM
rowo87's Avatar
dude i don't get fucked in the *** without lubrication... ummm... i wasnt having this problem before they messed around with the engine...
Old Oct 5, 2007 | 04:28 PM
Todd00's Avatar
I said I don't want a title!
Default Re: UGH THE PROBLEMS KEEP COMING!!! (rowo87)
How much was the head shaved? A shaved head causes changes in cam timing. This can be corrected with a camgear, but I wouldn't go that route just yet.
Also make sure they used the correct headgasket.
Otherwise that car would be back to them ASAP.
Old Oct 5, 2007 | 06:28 PM
he is asking how a head gasket has an affect on power steering. i just think ur pump is goin out or somethin is wrong with the pump. but u do get it in the *** huh?? only with lube? hhahah im jm w/ you
Old Oct 6, 2007 | 07:41 AM
thinknology's Avatar
Default Re: UGH THE PROBLEMS KEEP COMING!!! (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">How much was the head shaved? A shaved head causes changes in cam timing. This can be corrected with a camgear, but I wouldn't go that route just yet.
Otherwise that car would be back to them ASAP.</TD></TR></TABLE>
My initial thoughts... timing...
Your powersteering may also be going out (something doesn't sound right though). But timing would explain your power issue.
Old Oct 6, 2007 | 03:57 PM
skipbarber's Avatar
milling the head flat doesnt change the cam angle, it raises compression and not by much. there is certainly a spec though. as for the steering, what youre describing is common to the 6thgen civics, check your power steering housing for cracks and check the mounts. Sometimes the bushings wear out or maybe some bolts were removed and not put back but what youre feeling is the entire steering rack shifting from side to side. Your loss of power however, is a hole different ball game, it could possibly be an out of phase camshaft, but youd be throwing a code for that. speaking of which, do you have any CEL's?
Old Oct 6, 2007 | 05:19 PM
rowo87's Avatar
Default Re: (skipbarber)
hmmm now that you mention it there was an extra bolt left on the hood... im going to try and flush the oil and put cylinder sealent in it... no CEL has come on... the steering seems to have fixed itself put the power is low and the car just feels different... my poor baby
Old Oct 7, 2007 | 02:14 AM
jjzend600rr's Avatar
Im not sure about vale gaping on our cars but...when its not done correctly, the valves don't close or open correctly..so yea..Im not sure if you have non adjustivle ones...or ..yea..Im Drunk...sorry..good night..
Dezso3
Honda Civic (2006 - 2015)
Feb 21, 2015 08:24 AM
D16Z6racing
11
Jul 19, 2014 08:34 PM
Mitcher
Jul 19, 2007 09:43 PM
LUDER INTRUDER
Mar 15, 2006 11:54 PM
quikyEG
31
Oct 2, 2003 09:58 AM
