Question: Can a 4th gen prelude use a 5th gen prelude power steering pump & hoses?
Old Oct 5, 2007 | 01:42 PM
dudenalude's Avatar
Default Question: Can a 4th gen prelude use a 5th gen prelude power steering pump & hoses?
Hello I have a 4th gen prelude 1994 si with a JDM H22a motor & trans. The car does not have a power steering pump & wanted to ask if anybody knows if I can use a 5th gen prelude H22a4 power steering pump & hoses on my car. I think there interchangeable . Are the pulley diameters the same as well as bolt pattern on power steering pump so everything is plug & play? I have the exsisting power steering resevoir & rack pinion. Help fellas!
Old Oct 5, 2007 | 03:14 PM
dagle's Avatar
Default Re: Question: Can a 4th gen prelude use a 5th gen prelude power steering pump & hoses? (dudenalude)
i think the most important thing is if your holes line up with the P/S hose.. its the fat one with the metal valve on the end? if the holes dont line up correctly u cant use it.. otherwise i'd say the p/s pump will do its job.
Old Oct 5, 2007 | 04:12 PM
dudenalude's Avatar
Default Re: Question: Can a 4th gen prelude use a 5th gen prelude power steering pump & hoses? (dagle)
Alright well I'm going to to check it out this weekend to test fit it to make sure the three bolt holes line up with my cylinder head & that the hoses all fit correctly. Thanks & any additional input from anybody else would be greatly appreciated.
Old Oct 7, 2007 | 03:05 PM
dudenalude's Avatar
Well the verdict is in... A 5th gen 97-01 h22a4 power steering pump will not fit with a 4th gen 92-96 prelude power steering pump high pressure hose. The 5th gen pump will not bolt up to exsisting 4th gen high pressure hose to rack & pinion. Tried even swapping out the high pressure hose but, the 5th gen hose will not reach 4th gen rack & pinion to the 5th gen power steering pump. Have to give " Boarderx192 " a shout out for trying to make it happen. He's got plenty of 5th prelude parts for sale. Here's his link of for sale stuff:
FS: 1998 Honda Prelude https://honda-tech.com/zerothread?id=1527285
Hit him up if you need stuff. Take care all!
thirsk66
Mar 28, 2015 11:35 AM
oehawks3
Jan 6, 2013 04:21 PM
jay24k
Dec 8, 2009 06:09 AM
LukieLuc
May 25, 2007 08:41 PM
