b18 or b20? for 95 4dr teg
Old Oct 5, 2007 | 12:50 PM
mikesdb7's Avatar
Default b18 or b20? for 95 4dr teg
i am planning to buy and rebuild a motor for my 95 4dr teg LS. i am a bit of a purest when it comes to things and a tad bit too ****. i know a b18b would be the easiest because i can drop it right in and go. but i want more tourqe, for auto-x. so i was thinking b20. if i go with a b20 what do i need to know. is it a direct drop-in or will i have to modify things? most of the ones i have found are ODB2 as well but considerably cheaper. any help would be nice, and thanks in advance.
Old Oct 5, 2007 | 02:07 PM
Vday Kid's Avatar
Default Re: b18 or b20? for 95 4dr teg (mikesdb7)
if you decide to go b20, you can use your ls wiring harness and it'll plug right in. the b20 does have a nice flat torque line. but if you plan on building it, do not skip sleeving the block. b20 has weak cylinder walls.
latinf86
Jun 25, 2006 11:45 PM
twin336
Jan 2, 2006 10:02 AM
DriveSideWays
26
Dec 16, 2003 09:40 AM
russian_racer
16
May 13, 2003 11:51 PM
