Info on h22 swap
i have a h22 in my civic eg and it sits kinda akward....its leaning back which im pretty sure it suppose to but it also leans sidewards a little bit....the passenger side sits a lil higher then the driver side...its not that much of a lean though but its noticeable if you take the time to look at it...i just want to kno if thats normal, considering its a motor swap and all......the only thing i can think of is that the hole that was drilled out for the motor mount on the passenger side (i have hasport mounts) was cut a little to high causing the motor to lean a little bit.....
