Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
engine light is on!/maintenace required is on(HELP)
Old Oct 5, 2007 | 07:08 AM
m2s4drespecial's Avatar
Default ingine light is on!/maitenace required is on(HELP)
i have 2 problems on my car..1st wud be my check ingine light,it goes on sometimes and it shut's off later after 2 days.i think the only problem when the light goes on is when i start to PIN down my car,then it goes on,but when i PIN it down later it shuts off...the 2nd problem is i have a MAITENACE REQUID light on for like a month now..can u guys help on this??????wut shud i do?
Old Oct 5, 2007 | 07:22 AM
Curiouz_G's Avatar
maint required light you can shut off by reading the FAQ. they have it stated in there.
as for the CEL, id get it pulled instead of just letting it sit. you never know what it could be. you dont even have a code so we cant tell you what it can be
Old Oct 5, 2007 | 07:24 AM
fventura03's Avatar
how do you pin down your car?
Old Oct 5, 2007 | 10:27 AM
like wen i gun the car.like if am racing....
Old Oct 5, 2007 | 10:49 AM
Curiouz_G's Avatar
so when you floor your car when your racing? hm, get a code pulled when you get the CEL or else its just like shooting in the dark.
Old Oct 5, 2007 | 11:18 AM
thinknology's Avatar
Default Re: (Curiouz_G)
Error: Insufficient information.
Like they said maintenance required (usually routine maintenance, usually at set mileage points) can be reset.
CEL should be read so you can identify the problem.
Old Oct 5, 2007 | 06:42 PM
i-VTEC_DOHC's Avatar
full throttle
motorcycles, dirtbikes, mopeds = pin, pinning it etc...
automobiles = flooring it, punch it, get on it, etc...
hopefully this helped clear something up??
Nate13
Jun 5, 2009 06:51 AM
SiTR
Feb 14, 2008 04:19 PM
lgragera
Aug 6, 2005 05:15 PM
Nikoli
May 3, 2004 11:59 AM
eL
Oct 25, 2003 05:25 AM
