Spindle Nut
Old Jun 19, 2002 | 10:08 AM
TurBoXBirD16's Avatar
Default Spindle Nut
I am trying to swap my clutch
and i am removing my ball joint, but i can't take off my spindle nut !!!!
it's stuck in there !!
what can i do??
shooo t !!
it's a 93 civic
Old Jun 19, 2002 | 10:09 AM
spettinger's Avatar
Default Re: Spindle Nut (xbird)
your spindle nut? do you mean on the half shaft? or the ball joint on the bottom?
Old Jun 19, 2002 | 10:10 AM
Default Re: Spindle Nut (wreckedhatch)
the nut on the outside where u have to hammer that metal
let me find the exact word
Old Jun 19, 2002 | 10:12 AM
yes, it's called spindle nut
it's at the end of the driveshaft
Old Jun 19, 2002 | 10:15 AM
Lei Siew Long's Avatar
use at least a 24" breaker bar with a metal pipe over it as an extension. you can use a 12" breaker bar as well but, make sure you use the extension for the extra leverage to get the nut off.
if that doesn't work, try using a large impact gun with the air compressor compressed to at least 125 psi.
Old Jun 19, 2002 | 10:25 AM
Default Re: Spindle Nut (boostedeg6)
that's what i am going to do
but i don't have a break bar, i only have a small one.. shoot !
thanks anyways
Old Jun 19, 2002 | 10:35 AM
tonyxcom's Avatar
it makes it tons easier of you have the wheel on the car and the car on the ground. Then put a pipe over your breaker bar, then put a towel over the bar/pipe so that it wont sratch your wheels.
Make sure you have as little extension on the socket as possible. Making sure the bar is close to the wheel, thats why you need the towel.
Then STAND ON it. and BOUNCE.
Good luck. It helps to have two people so that the other person can make sure the socket stays on the nut.
Old Jun 19, 2002 | 10:51 AM
Mike P.'s Avatar
25 Year Member
Is the nut still staked? Make sure you push the staked part back out so it can turn. I usually use a punch and tap it back out with a hammer.
Old Jun 19, 2002 | 10:56 AM
thanks anyways
three words for you: BUY AND RETURN
Old Jun 19, 2002 | 11:11 AM
Default Re: Spindle Nut (tonyxcom)
that's what my uncle asked me to do too
i think i am going to do so
also, when removing those HEX?? do i need that ball joint remover as it says on the helm's???
that screw has a pin on it?? what's it called??
Old Jun 19, 2002 | 11:18 AM
for the lower control arm? if so, yes, you remove the pin and seperate the balljoint. you can rent one at a general autoparts store. but, from experience, those balljoint seperators need a lot of wiggling and jiggling to fit in between the lower control arm and the knuckle.
what i used was a three prong seperator that looks like a claw and that works really well for me.
Old Jun 19, 2002 | 06:35 PM
Default Re: Spindle Nut (ridge racer 2)
i bought a breaker bar , god, it works great, i love it, i won't just buy and return, i am going to keep it...
man, i spend alot of money on just tools !!!
but i got the job done !!
i have everything taken off now, but by the time i am done taking everything off, those machine shop isclosed already 6 pm, so i got to wait for tomorrow to resurface the flywheel, man.. i can't imagine how hard it is to put the tranny back...
but it was fun !! hehe
natemoore
22
Jul 21, 2014 03:01 PM
Dj Porboi
45
Aug 4, 2010 04:39 PM
92eg_h22
Suspension & Brakes
Sep 12, 2009 09:31 PM
raceACCORDingly
Apr 3, 2004 01:38 PM
elmalouno
Jun 2, 2003 04:29 PM
