so i wanted 2 be cool...and took the plastic off
Old Oct 5, 2007 | 04:47 AM
lilsicsoul's Avatar
Default so i wanted 2 be cool...and took the plastic off
this is what happend wen u dont put that plastic cover((the tech part))...this is a obd0 motor that its sopose to run on 2 o2 sensors what happens it i splice the 2 o2 wires to 1 o2..?..bolt fell off bolt got stuck while the motor was on! fuckt up brand new time belt
Old Oct 5, 2007 | 04:58 AM
lilsicsoul's Avatar
Old Oct 5, 2007 | 06:13 AM
Pee Wee's Avatar
Default Re: (lilsicsoul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilsicsoul &raquo;</TD></TR><TR><TD CLASS="quote">this is what happend wen u dont put that plastic cover((the tech part))...this is a obd0 motor that its sopose to run on 2 o2 sensors what happens it i splice the 2 o2 wires to 1 o2..?..bolt fell off</TD></TR></TABLE>
what is this, Armenian?
Old Oct 5, 2007 | 06:26 AM
wiZCo's Avatar
Stouts 'n' Scotch
A two year old can type better than this.
WTF does this say? I need an internetz translator sometimes.
Old Oct 5, 2007 | 06:29 AM
user 72830283's Avatar
holy ****...thats a motor mount bolt...how was it not tightened to spec or at least as tight as it could've been?
Old Oct 5, 2007 | 06:33 AM
Pee Wee's Avatar
Default Re: (wiZCo)
i think it says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilsicsoul &raquo;</TD></TR><TR><TD CLASS="quote">Yo Yo, i took off my timing belt cover to mad jdm son. But one of dem busta *** bolts on my mount popped off into my timing belt area. Now my belt looks like my momma's teeth. So how do i wire 2 of dem o2 sensors inta one?</TD></TR></TABLE>
which translates too:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]internetz_translator.com &raquo;</TD></TR><TR><TD CLASS="quote">I shouldn't own a vehicle</TD></TR></TABLE>
Old Oct 5, 2007 | 06:36 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (pr3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr3d &raquo;</TD></TR><TR><TD CLASS="quote">holy ****...thats a motor mount bolt...how was it not tightened to spec or at least as tight as it could've been?</TD></TR></TABLE>
Looks like it was cross-threaded and stripped. I don't see how this relates to a t-belt cover or O2 sensor wiring though. This guy must have been smoking crack when he posted, I don't know if anybody could seriously be that bad at English.
Old Oct 5, 2007 | 06:46 AM
CRXBart's Avatar
Default Re: (wiZCo)
I think it translates to I should jump in front of a speeding bus. For posting in such a way on the internet. The guy is 24, and can't make a remotely understandable sentence. Good thing he can post pics.
Old Oct 5, 2007 | 06:51 AM
Solid Motorsports's Avatar
Default Re: (CRXBart)
Oh, you meant to say that the bolt was loose, you didn't have a timing belt cover installed, the bolt fell down into the lower timing belt cover and damaged your timing belt.
Old Oct 5, 2007 | 06:58 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Solid Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solid Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Oh, you meant to say that the bolt was loose, you didn't have a timing belt cover installed, the bolt fell down into the lower timing belt cover and damaged your timing belt.</TD></TR></TABLE>
Somebody speaks internet-ese around here. Good job sir.
Old Oct 5, 2007 | 07:02 AM
Pee Wee's Avatar
Default Re: (wiZCo)
but isn't he asking if the bolt came out becuase he spliced the o2 sensors?
Old Oct 5, 2007 | 07:51 AM
Harlowe's Avatar
Function>Fashion
I took my plastic off
Old Oct 5, 2007 | 07:59 AM
IT GUY's Avatar
Default Re: (Harlowe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harlowe &raquo;</TD></TR><TR><TD CLASS="quote">I took my plastic off
did you throw bolts into the lower cover and start the car? That's what the OP did
Old Oct 5, 2007 | 10:36 AM
SIred91's Avatar
Rainman
OP is an idiot.
and then she vaccuum and pregnant. case close. i scare of roach too.
thats why no sensor 02 and belt bolt.
Old Oct 5, 2007 | 10:56 AM
Bob_760's Avatar
That's a pretty good translation but I can tell you aren't a fluent in internet-ese. You totally missed the question that was for some reason in the middle of that sentence which when translated reads:
"I have an OBD-0 B16A which is supposed to use two oxygen sensors. What would happen if I only used one oxygen sensor and spliced the wires together?"
The answer of course being <FONT COLOR="red"><u>Search</u></FONT>...
Old Oct 5, 2007 | 11:01 AM
Pee Wee's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">OP is an idiot.
thats why no sensor 02 and belt bolt.</TD></TR></TABLE>
damn, you got me. I was like "wtf, that doesn't make any sense?" Then i realized you were in fact, flaming the OP.
Old Oct 5, 2007 | 11:14 AM
wiZCo's Avatar
Stouts 'n' Scotch
*thud*
Old Oct 5, 2007 | 01:18 PM
ludesrv's Avatar
How is taking that plastic off cool? It's more cool to run that plastic, all the ricers take it off.
Old Oct 5, 2007 | 02:01 PM
STREETWERKZ's Avatar
Default Re: (ludesrv)
timing belts are overrated anyway.
start the motor up, stick your hand down there, and pull the bolt out.
Old Oct 5, 2007 | 02:12 PM
SFlCrx's Avatar
not everyone has timing chains like you or crx bart. k20 FTMF!
Old Oct 5, 2007 | 02:23 PM
Its me DUB's Avatar
Why was the car running when you did this?
Oh well, no biggie. From the looks of your avatar, you can afford a new belt. Pay someone to do it this time.
Old Oct 5, 2007 | 03:11 PM
KrenzyRyan's Avatar
Default Re: (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">i think it says:
ahahahahahha funniest crap eva
Old Oct 5, 2007 | 03:19 PM
Johnny-Red's Avatar
Default Re: (KrenzyRyan)
think it says:
Quote, originally posted by lilsicsoul »
Quote, originally posted by internetz_translator.com »
rofl
Old Oct 5, 2007 | 10:48 PM
nihad's Avatar
well the bolt is your problem dont leave it there when u put the new belt on
B20inDCinLBC
Oct 1, 2008 07:10 PM
Coltmorris
22
Oct 22, 2006 03:13 PM
shrug
Feb 21, 2005 07:13 AM
eMonk
Jan 28, 2005 03:33 PM
shadowstylz
Sep 3, 2003 07:07 PM
