coolant and oil mixing
Old Oct 4, 2007 | 10:19 PM
2wheelhunter's Avatar
Default coolant and oil mixing
so the car is an EM1 and its not the original motor.. we put in the new engine (hoping for the best) and the engine quickly started overheating.. it wasnt due to vaporlock i've mastered fixing that already.. but instead the coolant was mixing with the oil.. i presumed it was the head-gasket so we changed it (this wasnt my first time so i'm sure i did it rite) but the coolant is still mixing with the oil and visa versa.. would else could this be?
Old Oct 4, 2007 | 10:53 PM
HaiSpeedRacer's Avatar
Default Re: coolant and oil mixing (2wheelhunter)
crack in the block/cylinder?
Old Oct 4, 2007 | 11:12 PM
Default Re: coolant and oil mixing (HaiSpeedRacer)
that was a worse case option.. well how would i check for this, anyone?
Old Oct 4, 2007 | 11:15 PM
RedSix's Avatar
Inspecting the block.
Old Oct 5, 2007 | 10:33 AM
Default Re: (RedSix)
any other possibilities?
Old Oct 5, 2007 | 10:36 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (2wheelhunter)
1. Blown head gasket/improperly installed head gasket
2. Warped cylinder head deack surface or block deack surface or both
3. Crack in water jacket or any passage holding oil or coolant
Did you have the head resurfaced and pressure tested at a machine shop?
Old Oct 5, 2007 | 10:45 AM
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
no it was previously resurfaced (you can tell) and it wasnt the original headgasket either.. i'm thinking a crack in the water jacket
Old Oct 5, 2007 | 10:49 AM
lilredhonda's Avatar
i would also check water jacket you can very easily get oil mixed when messin with bad water systems in almost all motors
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">
no it was previously resurfaced (you can tell) and it wasnt the original headgasket either.. i'm thinking a crack in the water jacket </TD></TR></TABLE>
Well previously resurfaced doesn't mean anything if you're having to replace the head gasket. That head gasket you replaced leaked for a reason, and it very well could have been a warped cylinder head deck surface.
Oh well it sounds to me like you need to start looking for another engine, because IMO I'd never try to salvage an engine that has had coolant mixing with the very oil that is supposed to be lubricating my main bearings, rod bearings, cylinder walls, etc. etc. It'll never be right again.
Old Oct 5, 2007 | 10:50 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (lilredhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredhonda &raquo;</TD></TR><TR><TD CLASS="quote">i would also check water jacket you can very easily get oil mixed when messin with bad water systems in almost all motors</TD></TR></TABLE>
Exactly what does that mean? ...and since you obviously know what you're talking about can you tell us exactly HOW he could go about "checking the water jackets" so we can all see what to do?
Old Oct 5, 2007 | 06:01 PM
Exactly what does that mean? ...and since you obviously know what you're talking about can you tell us exactly HOW he could go about "checking the water jackets" so we can all see what to do?</TD></TR></TABLE>
lol
yeah either way... warped or cracked head or block... i'm in the search for a new motor.... again
thanks guys!
Old Mar 9, 2008 | 10:31 PM
s0uk's Avatar
i just helped my friend put an engine together, it sounds like you had the same situation we went through, we went through 3 head gaskets, had the head resurfaced and got new dowels for the head. instead of hooking everything back up and before putting the cams and stuff back on, just bolt the head down, connect all your hose and run water through the radiator and pump it, wait like 2-5 min for it all to flow through, if you didn't connect your oil line, you should see water coming out of it, if you do something wasn't plugged up in there. my buddy took his head to get cleaned and he had to change his valves on piston #1 since it was messed up but we eventually had to use a diff head. that's how the oil got into the radiator and how it got to the whole block, head, and oil pan. unbolt your oil pan bolt to see if water runs through that too. i'm not sure if this helps but that's what we did to trouble shoot the problem...
he got his head pressure checked and all that good stuff too. we finally figured where it was leaking after 2 weeks of trouble shooting...
98civc123
23
Sep 8, 2021 08:14 PM
EdSales
Apr 29, 2010 10:14 AM
lakerschamp2000
Apr 20, 2009 10:51 AM
apeek
Apr 16, 2008 02:23 PM
dwc7276
Jan 28, 2007 12:42 AM
