what size injectors for built gsr w/ ITB's????
Old Oct 4, 2007 | 09:08 PM
HATCHBACK GORILLA!'s Avatar
Default what size injectors for built gsr w/ ITB's????
j/w what size injectors I should go with....ive been advised to cange from my 310's to some 450's....any advice?....heres the current mod's
12.5:1 CR
JUN 3 Cams
Blox Intake manifold
RPM 65mm Throttle body
Endyn P&P head
81mm Endyn Rollerwave pistons (weisco)
Eagle rods
Balanced rotating assembly
Endyn Valvetrain
Skunk 2 cam gears
DC JDM itr header w/2.5 collector (being replaced)
ITR Tranny (USDM)
RC 310 CC Injectors
Sard fuel pressure reg.
Micropolished Crank
Unorthdox single rib pulley
Integra GSR Fuel Pump ( being replaced with walbro)
Ferrea stock sized valves
Ebay intake
Apexi N1 catback
Magnaflow Hi flow cat
will be switching setup to 52mm TWM ITB'S....& tunded on hondata
Old Oct 4, 2007 | 09:17 PM
b19coupe's Avatar
Default Re: what size injectors for built gsr w/ ITB's???? (HATCHBACK GORILLA!)
With those mods, stock injectors will be enough, even tunded on Hondata.
Seriously, you will not need anything bigger than 310's. Tuned.
Old Oct 5, 2007 | 06:18 AM
Default Re: what size injectors for built gsr w/ ITB's???? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">With those mods, stock injectors will be enough, even tunded on Hondata.
Seriously, you will not need anything bigger than 310's. Tuned.</TD></TR></TABLE>
thats what I was thinking.....unless I went turbo I didnt see any reason why my 310's couldnt do the job.....guess ill tell my friend if he wants me to upsize my injectors ill let him pay for them...lol
Old Oct 5, 2007 | 03:29 PM
Bisimoto's Avatar
310s are proper for your set up...good luck!
Old Oct 6, 2007 | 04:13 AM
Default Re: what size injectors for built gsr w/ ITB's???? (Bisimoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">310s are proper for your set up...good luck!</TD></TR></TABLE>
I really cant thank you enough Bisi....I will rep you to the fullest
Old Oct 8, 2007 | 09:00 AM
gonna stick with my 310's
phoshyzzle
Sep 3, 2009 09:43 PM
b18junkie
Sep 3, 2003 08:30 PM
haggar
Jul 30, 2003 12:12 PM
Rhetoric
Feb 9, 2003 06:55 AM
b18c-rDC2
Oct 22, 2002 01:32 AM
