F22 DOHC/SOHC
Old Oct 4, 2007 | 06:56 PM
omarisramo's Avatar
Default F22 DOHC/SOHC
i never knew that there was a dohc F22 i thought there was only F22 sohc.
check this out
http://cgi.ebay.com/ebaymotors...wItem
and this one
Old Oct 4, 2007 | 06:58 PM
JDM_Acccord's Avatar
Default Re: F22 DOHC/SOHC (omarisramo)
there's both....
Old Oct 4, 2007 | 06:59 PM
scabbs's Avatar
yeah I believe it's the JDM non vtec motor... dont remember what year accord it came out of.
Old Oct 4, 2007 | 07:01 PM
omarisramo's Avatar
what would be a better engine? the dohc or the sohc?
would you have to modify anything to place the dohc in
Old Oct 4, 2007 | 07:03 PM
scabbs's Avatar
Default Re: (omarisramo)
the dohc motor... kids on here turbo em... but alot of kids throw an h22 in their cars or they jus keep the sohc engin n turbo it... cause f's have endless possiblities... I think there are sum write ups in the accord FAQ that could prolly help you a lil more than I could.
Old Oct 4, 2007 | 07:07 PM
omarisramo's Avatar
good lookin out aki
Old Oct 5, 2007 | 02:35 PM
omarisramo's Avatar
what would be a better choice if im goning to stick with the f series?
Old Oct 5, 2007 | 03:12 PM
NeKe1point0's Avatar
[QUOTE=scabbs]... cause f's have endless possiblities... QUOTE]
well... the pic should explain what route i ended up taking and would also reccomnd !!! good luck
Old Oct 5, 2007 | 03:39 PM
omarisramo's Avatar
was there any fabrication?
and what type of ECU did u use?
Old Oct 5, 2007 | 03:57 PM
P28, but with any turbo setup u will need to do some fab work. the hardest part of the whole setup imo is routing ic piping, and mounting the ic. the rest was pretty simple and just requires the budget, and of corse basic automotive knowledge.. whatever u think ur budget is make sure you have double that amount for f-ups along the way or parts needing to be replaced when u get into it. i ended up doing a complete overhaul on my motor prior boost. (wanted it to last as long as possible) and jst look up a local turner in ur area in the i tuner directory and enjoy trust me, the power is amzing with boost. its almost as if it was meant for turbo. this was quoted off the "official f22 turbo thread" but these motors with boost preduce some crazy axle breaking torque !!!!
Old Oct 5, 2007 | 04:03 PM
omarisramo's Avatar
you have sweet set up. proir to turboing the car did you run the engine by itself.
im decing between the F22B1 or the DOHC F22 but rite now i dont have all the money
Old Oct 5, 2007 | 04:04 PM
not sure what u mean .. after the overhaul ? or be4 turbo all together ?
Old Oct 5, 2007 | 04:09 PM
Default Re: (NeKe1point0)
before i went w. boost i prep'd it for turbo, arp studs, fidanza fly, clutch, mild port and polish, etc. nothing done with the block or bottom end, imo nothing really amazing compared to some of the builds on here. all i was going for was fast but not crazy fast and what everyone that has converted honda dreams of ..... RELIABILITY !!!!
Old Oct 5, 2007 | 04:37 PM
oem_certified_accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeKe1point0 &raquo;</TD></TR><TR><TD CLASS="quote">before i went w. boost i prep'd it for turbo...nothing done with the block or bottom end, imo nothing really amazing compared to some of the builds on here. all i was going for was fast but not crazy fast and what everyone that has converted honda dreams of ..... RELIABILITY !!!! </TD></TR></TABLE>
in a nut shell what i am doing over the next few months...but boost will wait, i've heard bad feed about turbos in the winter
but yes, boosted F
Old Oct 5, 2007 | 04:46 PM
Tech-Nics's Avatar
if it was my choice i would go with the F22B SOHC.
Old Oct 5, 2007 | 04:50 PM
omarisramo's Avatar
im still undecided on what engine. whatever pops up first. thanx for everyones imput
Old Oct 5, 2007 | 04:58 PM
Default Re: (Tech-Nics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics &raquo;</TD></TR><TR><TD CLASS="quote">if it was my choice i would go with the F22B SOHC.
just got one a couple weeks ago for $450
good choice
Old Oct 5, 2007 | 05:07 PM
omarisramo's Avatar
yea i want the F22B1 tho. i have 200,000 miles and i wana upgrade a little so what ever pops up first
Old Oct 5, 2007 | 07:32 PM
i didnt get that because i have an lx, if i had an ex i would've bought another b1 motor.
Old Oct 5, 2007 | 08:16 PM
Default Re: (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord &raquo;</TD></TR><TR><TD CLASS="quote">
but yes, boosted F </TD></TR></TABLE>
boost is best when the air is cooler/denser; therefore, a turbo-charged car should run a lot better in the winter than the summer.
Old Oct 5, 2007 | 09:18 PM
Murk 'EM's Avatar
Default Re: (JDM_Acccord)
dohc f22b ftw.. got mine for 700 shipped to my door, its out of a 93 (ish) prelude in japan, all you need to swap this motor in is a prelude (92-96) driver side motor mount.. fits right in no problem
Old Oct 6, 2007 | 06:25 AM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">
boost is best when the air is cooler/denser; therefore, a turbo-charged car should run a lot better in the winter than the summer. </TD></TR></TABLE>
Maybe is talking about hearing oil gum up from it being hot and losing heat real quick?
Old Oct 6, 2007 | 02:52 PM
Default Re: (Murk 'EM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Murk ’EM &raquo;</TD></TR><TR><TD CLASS="quote">dohc f22b ftw.. got mine for 700 shipped to my door, its out of a 93 (ish) prelude in japan, all you need to swap this motor in is a prelude (92-96) driver side motor mount.. fits right in no problem</TD></TR></TABLE>
no wiring harness issues?
Old Oct 6, 2007 | 02:56 PM
Murk 'EM's Avatar
nope.. the only rewireing that was done was the external coil (accord) to internal coil on the distributer... it was like 2 wires and bam done.... but if you can id say stay with the external coil
Old Oct 6, 2007 | 03:43 PM
how about parts & performance.. u happy with aftermarket support and output power of the dohc?
