shift linkage/shifter question
Old Oct 4, 2007 | 05:18 PM
1kleenef's Avatar
Default shift linkage/shifter question
i am about to purchase two shifters from a guy but i have a question will any dual bend shifter fit my d series shift linkage and he says he also has a gsr shifter that is modified to fit a 92-00 civic will this also fit in efs thanx and plz dont flame just wondering before i buy
Old Oct 4, 2007 | 05:24 PM
The_Undertaker's Avatar
75.168.105.221
B series shift linkage and d series shift linkage are not interchangable meaning the b series will not fit on d series trannies. As for the other dual bend shifter i dunno may be a different shape. But buy a d series if you a d series tranny
Old Oct 4, 2007 | 05:42 PM
1kleenef's Avatar
Default Re: (loldohcvteclol)
i have the right shift linkage its just i want to kno if there is a difference between shifters that i can use?
Old Oct 4, 2007 | 05:44 PM
75.168.105.221
yes there is a difference on d series linkage where it bolts on tranny is for been vertically mounted. On b series its bolted on it side.
Old Oct 4, 2007 | 05:50 PM
1kleenef's Avatar
so if a shifter was modified to be used in a 92-00 d series civic should it also fit in an ef d series civic shift linkage
Old Oct 4, 2007 | 05:52 PM
75.168.105.221
Precisely, but you said 92-00 civic 1999-2000 civic were b16. Are you sure you meant by 92-98?
Old Oct 4, 2007 | 05:59 PM
1kleenef's Avatar
yes but also there were 99-00's that had d series in them also but ur saying it should work if it was in a d series because efs are no different in that sense? Thanx
Old Oct 5, 2007 | 04:58 PM
mahatma's Avatar
Default Re: (1kleenef)
yes the shifter will work
b20hatchek
Mar 7, 2013 08:48 PM
CRX MASE
Sep 6, 2006 07:52 PM
deviant1
Apr 5, 2004 10:40 PM
poop32145432
Jan 18, 2004 12:44 AM
dose
Nov 11, 2003 01:51 PM
