LS/vtec tune
Would an Apexi Neo be enough to tune a mild LS/Vtec Build? Would it be safe to break in at least and get it inspected (Considering the Tuner is Competent)? Reason is It wont pass If I convert to OBDI to tune.
EM1 Chassis
B18a1 Block( 81.25mm Micropolished/balanced crank)
ACL Bearings
ARP Bolts
Shotpeened LS rods
RS Machines PR3 Pistons
ITR Oil/Water Pump
PR3 head
GSR Cams
Crowere Springs/Valves/Retainers
Mild PnP and Valve Job
EM1 Chassis
ACL Bearings
ARP Bolts
Shotpeened LS rods
ITR Oil/Water Pump
PR3 head
GSR Cams
cleanazcoupe
Sep 14, 2010 03:39 PM
