CRX Si w/Integra caliper and corrado rotor possible? Searched!
Hello all,
About a year ago I came across a thread claiming you could could use Integra calipers with corrado rotors using Fastbrake's adapter kit. I've been seaching and an't seem to find it in the FAQ 2.0.
Suggestions?
Thanks!
Suggestions?
Thanks!
Well, I went to the site and it doesn't specify if you can use Corrado rotors or if you have to get the Prelude VTEc w/ the 4x100 bolt pattern. Which ones are you using?
Thanks!
Thanks!
Bump because I want to know as well. Anyone have the specs on the Corrado rotor>
I personnally have run the Prelude VTEC rotor redrilled to 4x100 (PM me if you need a pair). Does the corrado rotor use the same centerbore or factory retainer screw location holes?
RC000E
Suspension & Brakes
Mar 21, 2009 11:32 PM
Drew M
Oct 9, 2004 01:27 PM
Petah
Aug 14, 2002 01:47 PM
