List of weights for Honda engines/transmissions?
Hey, all. I have a question about the weights of the different Honda engines and transmissions. I have searched, and I looked through the FAQ. I also hit Google for a little while, but didn't get much.
Does anyone know where I can find the weights of the different series of Honda engines? D-series, B-series (either B16 or B18), H-series, K-series?
In the FAQ thread, I found information on partially-built engines, and a little on transmissions. I also found the following numbers:
complete 1995 H22A1 drivetrain, minus the lower exhaust manifold, no accessaries other than the alternator: 475lbs.
d15b vtec weighed 306 pounds in the same condition
For short blocks:
D-series, just under 100 lbs
B16, 104 lbs
H22, 131 lbs (123 + 8 for balance shaft)
Transmissions:
B-series, 90 lbs
H-series, 95 lbs
Does anyone have data for a non-VTEC D-series engine or drivetrain (ideally D16A6), a cable-operated D-series transmission, or for the K-series engine that is getting to be a more popular swap these days and its transmission?
Thanks!
--DD
For short blocks:
B16, 104 lbs
Transmissions:
B-series, 90 lbs
H-series, 95 lbs
Thanks!
--DD
http://hondaswap.com/engine-bu...11461/
is this what your looking for?:
88-91 CRX/Civic engine weights:
CRX HF D15B6 - 195lbs (dry)
CRX/Civic DX D15B2 - 208lbs (dry)
CRX/Civic Si D16A6 - 219lbs (dry)
JDM DOHC ZC - 232lbs (dry)
JDM B16A - 309lbs (wet)
88-91 CRX/Civic L3 D-series transmission - 63lbs
check this out as well: https://honda-tech.com/zerothread?id=879294
D-Series cable transmission is around 63~lbs, hydraulic came in a little heavier at 67~. I've shipped both of these before.
That's exactly what I was looking for, gursh! The links are great. And Doc, thanks for the info on trans weights too.
I think I may add these to the bottom of the thread that's referenced in the FAQ, if I have your permission?
--DD
--DD
VtecCarHauler
Sep 28, 2006 02:44 PM
phaderlanx
Jul 14, 2002 09:49 AM
b18, california, civic, crx, d15b, ef, engine, engines, hatch, honda, honde, transmission, transmissions, weight, weights
