so will this work?
Old Oct 4, 2007 | 12:49 PM
hyabusa hunter's Avatar
Default so will this work?
well, i shattered my inner CV joint on the passenger side (US DRIVER SIDE) on my boosted JDM lude 1992 vtec here are the pics
so anyway, im a bit broke at the mo, found a 5th gen axle at a junk yard and i know it wont fit my 4th gen, but my question is if i remove the outer CV joint from my 4th gen axle and put in on the 5th gen, well it be ok?
Old Oct 4, 2007 | 01:13 PM
bb_one's Avatar
Default Re: so will this work? (hyabusa hunter)
The 5th gen axle has the same spline size as the 4th gen. So it should fit in your 4th gen hub, but the difference is in the length. I do not think it's that significant, but I am not sure if it'll have any issues with the 4th gen hub.
I did a 5th gen knuckle swap on my 4th Gen and I've used both axles before. Only difference is if I used 4th gen axles with the 5th gen hub, I had to use washers on the axle nut as there was not enough length to apply the proper torque on the axle nut.
Modified by bb_one at 4:44 PM 10/4/2007
Old Oct 4, 2007 | 01:31 PM
Default Re: so will this work? (bb_one)
THE 5TH GEN AXLES DID NOT WORK IN MY 4TH GEN HUB. the 5th gen rubbed against a metal ring type fixture which is just behind the wheel bearing onmy 4th gen. the CV joint on the 5th gen is different to the 4th gen CV joint.
my question was if i put the 4th gen CV joint on the 5th gen axle will it work ok? has anyone tried this?
Old Oct 4, 2007 | 01:43 PM
bb_one's Avatar
Metal ring fixture?
Are you reffering to the wheel bearing cover or the ABS ring on the axle?
Old Oct 4, 2007 | 09:59 PM
must be the wheel bearing fixture. can anyon answer my question?
Old Oct 5, 2007 | 12:40 AM
Rosko's Avatar
must be hitting that little dust shield piece behind the wheel bearing.
sounds like you have all the pieces, why not try it and see!!
Old Oct 5, 2007 | 06:12 AM
rleonekc's Avatar
Default Re: so will this work? (Rosko)
i had that same problem with my civic
Thepowderblue
Dec 29, 2011 09:50 PM
hella_usdm
Jan 9, 2007 01:05 PM
shadowz
Jun 14, 2004 12:04 PM
TurboSam
May 3, 2004 10:19 AM
