JDM Power Folding Mirrors
Old Oct 4, 2007 | 12:43 PM
crj_lll's Avatar
Default JDM Power Folding Mirrors
I have successfully finished installing my mirrors. When I first put them on, they were closed. When I hooked them up, they began to open and close opposite each other when I push the button.
First thing I did was double check the wiring to make sure my colors matched up. Everything checked out.
The next thing I did was just unplug on of the mirrors and and see if I could operate one of the mirrors on their own and then plug the last one in.
Obviously that did not work.
Does anyone have any suggestions?
Old Oct 4, 2007 | 12:56 PM
Acidcrakker's Avatar
Default Re: JDM Power Folding Mirrors (crj_lll)
Doesnt sound too succesful. How is the wiring on that set up?
Just positive andnegative wires? Or is there Acc wires?
Old Oct 4, 2007 | 01:16 PM
crj_lll's Avatar
Default Re: JDM Power Folding Mirrors (Acidcrakker)
What are you referring to as ACC wires? There are 7 wires in the set up. They have all been checked and double checked.
Old Oct 4, 2007 | 01:33 PM
Okay. So this what I understand. You have your folding mirros wired up to a toggel switch. And when you flick the button on or off One mirror goes 1 way and the other the opposit. Right so far?
Sounds like the polairty on one of the mirrors ir backwards. Try and switch around your wires a little. Like negative to positive and vice versea. Make sure you find out what wires power the miorror to open and close. They sound like they are backwards. Even thought the colors match up it might be defective.
Hope that helps
Spelling sucks
Old Oct 4, 2007 | 02:39 PM
MLBZ521's Avatar
Just push one of the mirrors manually to where they are both at the same place. Then try it..
If that doesn't work, I'll see if I can help more.. I have them working on my car, for the most part at least... lol
Old Oct 4, 2007 | 02:46 PM
NormanBates's Avatar
http://www.geocities.com/dwnlow91/JDMmirror.html
Old Oct 4, 2007 | 04:03 PM
crj_lll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Okay. So this what I understand. You have your folding mirros wired up to a toggel switch. And when you flick the button on or off One mirror goes 1 way and the other the opposit. Right so far?
Hope that helps
Spelling sucks</TD></TR></TABLE>
It is commonly grounded and there is positive wire for each action. I know I can switch the wires, but I want to know if anyone else has had this problem and found out the problem. I do not just want to reat the symptom but solve the underlying problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">Just push one of the mirrors manually to where they are both at the same place. Then try it..
If that doesn't work, I'll see if I can help more.. I have them working on my car, for the most part at least... lol</TD></TR></TABLE>
When I do that, the mirror goes back to how it was before. I am wondering if this is a relay issue.
Old Oct 4, 2007 | 04:04 PM
crj_lll's Avatar
Default Re: JDM Power Folding Mirrors (NormanBates)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NormanBates &raquo;</TD></TR><TR><TD CLASS="quote">http://www.geocities.com/dwnlow91/JDMmirror.html</TD></TR></TABLE>
Thanks for the link, but as most on here know, prelude mirrors are not the same as the rest. They use a 7 wire relay unlike the integra link you sent me.
Old Oct 4, 2007 | 05:27 PM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crj_lll &raquo;</TD></TR><TR><TD CLASS="quote">When I do that, the mirror goes back to how it was before. I am wondering if this is a relay issue. </TD></TR></TABLE>
It goes back to where it was before when you push the button? Or by itself?
Fold them both in, turn off the car, remove key, where there's no power, and then turn the car back on, and push the button. Does that make them work correctly?
What kind of power are you supplying to the mirrors? Where are you getting it from? Is it direct from the battery, like the memory wire from the stereo or from the ignition, power when the ignition is on?
gnxpro24
Jul 5, 2011 01:48 AM
APMQ
Mar 7, 2009 10:06 PM
notloudenough
Audio / Security / Video
Jan 10, 2006 09:13 PM
E36 Guy
May 23, 2005 10:59 AM
