ECU??????
Old Jun 19, 2002 | 08:54 AM
trborex's Avatar
New User
Default ECU??????
i've been on this board for awhile now but never really posted. But i figured u guys were the best ppl to ask so here goes.........
i swapped in a d16y8 in my 90' CRX Si. i have also added a JRSC,centreforce clutch,10.4mm plug wires,blah blah blah..........
i was having a bit of detonation in the begining(I figured it was cus the JRSC was made for the d16a6). however i solved the prob by retarding the timing alot and upping the fuel on the JR auxilary FPR.
My question is will it have a better flow of fuel if i put in a ECU from a 90' teg? right now i'm runnin the stock CRX ECU and harness. i don't have a fuel pressure regulator or any fuel upgrades as of now(doing the full fuel system next).
so will it be ok cus the teg ECU is for a DOHC and i have a SOHC. jus wanted to know if it'll feed the engine more fuel.
sorry for it being so long but i need it to run rite TIA!!
Old Jun 19, 2002 | 09:40 AM
-TJ's Avatar
-TJ
Default Re: ECU?????? (trborex)
what you really need is a higher volume fuel pump and a set of injectors.
high fuel pressure and retarded timing are just band-aid solutions to the real problem - not enough fuel.
I don't think a 90 teg ECU is going to help much.
Old Jun 19, 2002 | 10:27 AM
trborex's Avatar
New User
Default Re: ECU?????? (-TJ)
i know i have to do the fuel system and honestly all i'm looking for at teh moment is a "band-aid" solution. so u think the teg ECU work do anything at all?
Old Jun 19, 2002 | 11:02 AM
Malgerus's Avatar
It might help a little, but as previosuly mentioned it's just a band aid solution. Get a nice high flow Holley fuel pump, and I've heard that 92-96 prelude injectors will work and provide a nice high flow... can anyone verify this??
Old Jun 19, 2002 | 11:28 AM
trborex's Avatar
New User
Default Re: ECU?????? (89_Y_49)
ok but i gues my main oncern is that will anything get fucked up if i put this ecu in?
Old Jun 19, 2002 | 12:05 PM
Malgerus's Avatar
Is your detonation part throttle or full throttle? JRSC's are known for this part throttle detonation problem... I always hear about it. Anyways, the 'Teg ECU shuld not hurt anything... look at all the guys switching from Pm6's to 89' TEG ECU's with their ZC's. All you'll get is a higher redline and slightly richer fuel maps, but I don't think they'll help that much.
Old Jun 19, 2002 | 12:10 PM
trborex's Avatar
New User
aight thats all i needed to know. i actually have one laying around so its not a big deal. jus wasn't sure about the SOHC and DOHC thing.........i know ppl use teg ecu but they usually have a DOHC swap
Old Jun 19, 2002 | 02:36 PM
trborex's Avatar
New User
Default Re: ECU?????? (chrisonepointsix)
i have a d16a6 exhaust manifold on..........for the intake i have a JRSC
Lquin
Nov 5, 2011 06:01 AM
Imissvtec
Jun 7, 2007 10:28 AM
Drag4Life723
Apr 12, 2004 08:12 PM
BonsaiGT
Mar 10, 2003 09:21 AM
tbisme
Jan 3, 2003 07:43 AM
