crx wont start after fill up
Why is it that my crx chooses when it doesn't want to start? And why is it always right after I put gas in my tank? Also why is there always a real heavy gassy smell? I didnt notice any leaks, and my gas cap is tight. What can that be from?
Sounds like you do indeed have a leak... But a slow leak. You can try removing the package tray in back and seeing if the smell gets stronger; if it does then something around there is leaking. Likely candidates would be pretty much anything that bolts onto or into the tank, the fuel hoses, and the filler pipe. Especially the filler pipe...
--DD
--DD
coilback
Oct 12, 2006 06:19 AM
MulletManRockStar
11
Sep 19, 2004 02:44 AM
