auto2man swap on 95 civic
i know the write-ups say that you need to use the manual intake mani cause of the throttle cable diference, but it there ANY way to use the auto intake and still make it work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">i know the write-ups say that you need to use the manual intake mani cause of the throttle cable diference, but it there ANY way to use the auto intake and still make it work?
All you do is change the throttle cable, not the intake manifold. Either way you only change the cable if your going to use manual pedals. 96-00 have to change the intake manifold for a different reason.
Using a Auto gas pedal you use a auto throttle cable according to the engine: aka b18b-Use b1b8 auto cable.
d16-d16 auto throttle cable
Using a Manual gas pedal you use manual cable for the engine: aka b18b engine-use b18b manual throttle cable.
d16-d16 manual throttle cable.
Difference in the cables is the end that mounts to the pedal, also different engines have different lengths of throttle cables. Integra cable is longer then civic throttle cables.
auto cables end comes to a T shape, manual end is like a circled tip.
Also somtimes freak of nature cables exist, and you may have to switch the throttle cable bracket around that sits on the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
All you do is change the throttle cable, not the intake manifold. Either way you only change the cable if your going to use manual pedals. 96-00 have to change the intake manifold for a different reason. </TD></TR></TABLE>
What reason is this? I thought the only reason you would change the entire intake manifold was if you were gona change the pedal assembly, like you stated above. Does anybody have information on this?
92-95 you do not have to do anything to the intake manifold. As in my previous post all you do is change the cable according to the pedal being used and the engine being used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon »</TD></TR><TR><TD CLASS="quote">92-95 you do not have to do anything to the intake manifold. As in my previous post all you do is change the cable according to the pedal being used and the engine being used.</TD></TR></TABLE>
I was refferring to the 96'-98' civics.
I personally never did a 96-00, but i found this in the FaQ section.
Intake Manifold and Throttle body: You need a y8 manual intake and for throttle body we used an LS throttle body. You could use any manual throttle body, i suggest y8 so you dont have to play with the map. Make sure you get a 2 wire IACV with the intake because if you dont have that you will throw a code and run like ***. We also got a new intake manifold (Y8, use that even if your using a y7 head Part #: 17105-P2F-A02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsjon »</TD></TR><TR><TD CLASS="quote">I personally never did a 96-00, but i found this in the FaQ section.
Intake Manifold and Throttle body: You need a y8 manual intake and for throttle body we used an LS throttle body. You could use any manual throttle body, i suggest y8 so you dont have to play with the map. Make sure you get a 2 wire IACV with the intake because if you dont have that you will throw a code and run like ***. We also got a new intake manifold (Y8, use that even if your using a y7 head Part #: 17105-P2F-A02 </TD></TR></TABLE>
Thanks for bringing that up. I have read this before but still dont understand why it is necessary.
Reason you change out the intake manifold (only on y8 really, y7 you dont need to) is because of the IAC. Auto IAC on 96-00 are all 3 wire IAC. y5, y7 are 3wire in auto and manual form so they dont matter. Y8 are 2wire manual and 3 wire IAC. If you swap anything other then a y5, y7 you need to convert to 2 wire.
dem0nk1d
Aug 15, 2007 12:30 PM
zx9rbart
Nov 7, 2006 09:27 AM
itsmike
Jun 20, 2006 10:32 PM
