crx keeps stalling after start up
Old Oct 4, 2007 | 08:09 AM
kaychi's Avatar
Default crx keeps stalling after start up
i have a problem guys. i have a 90 crx dx and just did a swap over to a z6 w/ obd1 conversion and everytime i startup the car it starts up but then it dies a couple seconds later. all the wires seem to be fine, what could be causing this?? please help!! thank you
Old Oct 4, 2007 | 12:51 PM
wiZCo's Avatar
Stouts 'n' Scotch
Any Check Engine Lights? Let's start there. Also, have you tested the main relay?
Old Oct 4, 2007 | 12:53 PM
SIred91's Avatar
Rainman
Default Re: (wiZCo)
check fuel pump?
Old Oct 5, 2007 | 08:31 AM
kaychi's Avatar
Default Re: crx keeps stalling after start up (kaychi)
there are no check engine lights. i was thinking the main relay too, but could it having anything to do with the obd0 to obd1 jumper harness??
Old Oct 5, 2007 | 12:14 PM
danmdevries's Avatar
Does it die when you give it gas?
When it starts is it idling poorly?
Old Oct 5, 2007 | 12:27 PM
65stang90crx's Avatar
Default Re: crx keeps stalling after start up (danmdevries)
I would inspect and test the distributor and the ignition system, including timing.
Old Oct 6, 2007 | 05:50 PM
kaychi's Avatar
Default Re: crx keeps stalling after start up (65stang90crx)
i've checked the spark and fuel and they're all good. the car just starts like normals then dies 2 seconds later. i will check the ignition system. could the conversion wiring be doing this too??
Old Oct 6, 2007 | 06:12 PM
b18c4g's Avatar
take a hammer and gentley tap on your IAC, somtimes they stick, causing a initial start-up, and then to die out. If you can keep your car running with the gas pedal, but it dies out when you let off, that sounds like an Idle Air Control Valve (IAC). Hope this helps.
Old Oct 6, 2007 | 06:49 PM
SamN's Avatar
What ecu are you running?
Old Oct 7, 2007 | 01:09 AM
~sp33~'s Avatar
EFB055
I have the same problem, although its tempermental and can not happen for weeks. Then i start it, no matter how much gas i give itll die within a few seconds, then wont start for about ten mins. I've got a new distributer coming, ill let you know if it fixes the problem.
Old Oct 8, 2007 | 08:33 AM
kaychi's Avatar
Default Re: crx keeps stalling after start up (b18c4g)
i'm running the p28 ecu, i'll try taping the IAC to see if that works.
Old Oct 8, 2007 | 08:44 AM
alscrx's Avatar
Def check your timing. Also check the basics, Air, fuel, spark
Old Oct 8, 2007 | 05:44 PM
kaychi's Avatar
Default Re: crx keeps stalling after start up (alscrx)
got the car runnin but it still cuts out cause it getting to much gas?? umm when putting a d16z6 motor in a crx should i run the z6 injectors or should it switch i with the crx injectors??
rupensane
Sep 3, 2009 09:54 AM
headhunter
May 4, 2009 02:14 PM
IIDIEIV619
Sep 28, 2006 08:22 AM
blakryder1
Sep 11, 2004 10:04 AM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
