Got it running again, but leaking oil by crank pully
Well i figured out the spark problem, and put the washer on behind the crank pully that hold the timing belt straight, but now that damn thing is leaking oil from the seal. When i had it on running for the first time no oil but after i fixed the timing belt slipping over now that bastered leaks, should i just buy a new seal and replace it?
