bitch pin
does a d-series have the little pin that goes through the shift linkage?
what do most people use to get them out, i know sometime a punch would work but what size punch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">i used pliers</TD></TR></TABLE>
then yours wasnt that tight...... i had to cut mine then use an air chissle with a punch on the end
yea that little ****** is a bitch, just use a 12mm bolt, might be a 10mm but i am pretty sure it's a 12mm. it works perfectly every time
remember that bitch pin expands so if your putting something(like a punch that is tapered) it goes on the inside of the pin and expands it, youll never get it out.
use the 12mm, and hold the bolt with some needle nose pliers and whack that ****, works on first punch EVERYTIME
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 »</TD></TR><TR><TD CLASS="quote">while we're on the subject...anybody know the part number for the pin? Or will a standard 8mm pin work?</TD></TR></TABLE>
part number is 94305-80222 costs about $1 at your local honda dealership
Easiest way to deal with it is to take it off with the transmission when you pull the engine or tranny. No reason you can't do that. Just be careful not to bind and bend it when you're lifting the motor out of the bay.
lol never knew it was called the bitch pin. ive made up several other names for it tho. yea i used a punch and hammer. once or twice i left it on the tranny while i was taking it out. just removed the whole trans and then punched it out.
I use a air hammer with a special punch that goes down in the pin a litle bit, and .. works amazing when you just hit a button and it pops out.
Cool Cool Island Breezes. BOY-EE
AC compressor bolt. I invented that ****. Just get one from a junkyard, though....cuz you're going to ruin it.
dont use a bolt.. yeah its easier but if honda wanted it to be easy to get out they would have made it easier to get out... using a bolt is going to slop your shifing up (i can tell some others may not) dont use a bolt seriously .. how often are you taking your trans/motor out of your car to use a bolt for "ease" of removal use whats suposed to be there
Me too, I've done numerous swaps etc.. never had a problem with a punch and hammer or pilers.
Guys stop being a wussy
if helms say do it, then do it!!!
and stop wasting internet bandwidth and space!!
nuff said!
sorry noobs, you have to tuffing up and work on cars thats driving in all weather and not parked under dealership umbrellas brand new with every nut and bolt hand tightned.
nuff said!
ok ive done atleast 50 swaps and the perfect size thing for a bitch pin is a 1/4" craftsmen extension. one good hit and its out... perfect size like no joke it fits like a honda oem tool!!!!
