Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
96 Odyssey - door lock actuator
Old Oct 4, 2007 | 05:52 AM
njungeb's Avatar
Default 96 Odyssey - door lock actuator
I have a problem with the door lock actuator in my Odyssey. When you use the key fob to lock the doors it continues to try to lock for a few minutes. In looking for an actuator to use for replacement, can I look for ones from different Honda models (Accord) or am I restricted to a replacement from only an Odyssey? Also I am assuming whichever model it is from it would need to be a four door model and not two door, is that correct? Any help is appreciated. Thanks!
Old Oct 4, 2007 | 06:03 AM
Ross 2.0's Avatar
In a Junkyard near you.
It's probably the same as an Accord. Just save yourself the hassle and buy one from a dealership.
Old Oct 8, 2007 | 05:28 AM
Duane_in_Japan's Avatar
Default Re: 96 Odyssey - door lock actuator (njungeb)
No answers here I guess, you will need to contact a junk yard, they have books on what parts will swap to different vehicles. YES, the actuator is your problem. Order a used one on line for an Odyssey.
Old Oct 11, 2007 | 09:46 AM
YakuzaDemon's Avatar
Default Re: 96 Odyssey - door lock actuator (Duane_in_Japan)
You can also go to the dealer and pick up the door lock actuator, they have them in stock all day everyday most of the time.... just expect to pay a little more but it's there. Easy to install also.
DFH
Nov 23, 2014 05:32 PM
rubenmed
Nov 25, 2012 01:46 AM
rlansdon
Jun 2, 2008 10:06 AM
honda_accord_215
Nov 18, 2005 10:15 PM
fe519
Oct 30, 2002 04:19 PM
