Suspension & Brakes Theory, alignment, spring rates....
EJ 96-98 EX front brakes on a CX?
Old Oct 4, 2007 | 12:03 AM
J_Marc's Avatar
Default EJ 96-98 EX front brakes on a CX?
Ok this should be simple, there is a wrecked EX locally, EX front brakes are bigger than CX front brakes, aren't they? What is needed to put these 97 EX brakes on my 96 CX? I already know I'll need 14" wheels to fit over the caliper so there's no need to mention that. Is this a bolt on procedure?
Old Oct 9, 2007 | 08:37 AM
roastbeefrichie's Avatar
Default Re: EJ 96-98 EX front brakes on a CX? (J_Marc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_Marc &raquo;</TD></TR><TR><TD CLASS="quote">Ok this should be simple, there is a wrecked EX locally, EX front brakes are bigger than CX front brakes, aren't they?</TD></TR></TABLE>
the EX brakes are bigger. the CX brakes uses a 9.4" (19mm) rotors, the EX uses a 10.3" (21mm) rotors...same rotors found on the 90-01 integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_Marc &raquo;</TD></TR><TR><TD CLASS="quote"> What is needed to put these 97 EX brakes on my 96 CX? I already know I'll need 14" wheels to fit over the caliper so there's no need to mention that. Is this a bolt on procedure?</TD></TR></TABLE>
the complete EX knuckles (spindles, hubs, calipers), pretty straight forward. you'll need an alignment after the swap
Old Oct 10, 2007 | 08:14 PM
Targa250R's Avatar
be professional
Don't forget to pick up the EX 14" spare tire/wheel as well if you carry one.
You will probably want to swap in the EX master cylinder also. The larger front caliper pistons require more fluid to move, and using them with the smaller CX master cylinder will result in a long pedal travel.
goforbroke
May 5, 2006 11:45 AM
NickW
May 27, 2005 03:37 PM
2muchPSI
Apr 7, 2005 11:12 AM
ROOROWNS
Mar 20, 2005 08:49 PM
gato5254
Aug 25, 2004 06:14 AM
