Synthetic oil
Old Oct 3, 2007 | 08:52 PM
leemikemphstn's Avatar
Default Synthetic oil
Another question: I'm using Royal Purple in my '98 Prelude and going through a quart every three tank fulls. Is this 'normal'? A buddy of mine works for Comp Cams here in Memphis, and Comp swears by Royal Purple. I was running 5w-40, but changed to 10w-30 with no change in oil consumption. The car has (only) 129,000 miles so I don't think engine wear would be a problem. But, for some reason it's 'burning' oil (I guess) or the oil is so slick it's slipping past the rings. Any ideas?
Old Oct 3, 2007 | 09:07 PM
AaronW's Avatar
Default Re: Synthetic oil (leemikemphstn)
Are you in VTEC a lot? That much oil consumption seems excessive, an h22 will typically burn a quart of oil every 3,000 miles or so. Many burn less though.
Also, you might be leaking it instead of burning it.
When did you switch to synthetic? Did it have the oil problem with regular oil?
Old Oct 3, 2007 | 09:14 PM
Acidcrakker's Avatar
You are buring oil or leaking oil. 1 quart if oil every three gas tanks is too much.
Old Oct 4, 2007 | 07:18 PM
ECX's Avatar
ECX
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leemikemphstn &raquo;</TD></TR><TR><TD CLASS="quote">Another question: I'm using Royal Purple in my '98 Prelude and going through a quart every three tank fulls. Is this 'normal'? A buddy of mine works for Comp Cams here in Memphis, and Comp swears by Royal Purple. I was running 5w-40, but changed to 10w-30 with no change in oil consumption. The car has (only) 129,000 miles so I don't think engine wear would be a problem. But, for some reason it's 'burning' oil (I guess) or the oil is so slick it's slipping past the rings. Any ideas?</TD></TR></TABLE>
I just answered this same question in another thread; if the motor hasn't seen synthetic since day one, it will leak. The seals are used to one type of oil, synthetic has detergents in it that will take away the seals over time, it cleans so good that it will cause oil leaks.
highwhey
Nov 11, 2010 05:53 AM
powerdbygarrett
Apr 28, 2008 07:28 AM
digitalayon
Mar 13, 2005 07:55 AM
HybridGSR1
Jul 4, 2003 07:37 AM
osuPrelude
Oct 22, 2002 05:24 PM
